- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Stacey007
Where have you put your amp / wires | |
OK so with the help of custom90steve on the forum I think I know what I need to wire to what in order to install my old Skool Rockford Fosgate amp
I have a 110 SW so was thinking under the passenger seats when you roll them forward? so then the wires from the battery box isn't far and from front to rear speakers not bad... I need it reasonable protected as I do load stuff up sometimes but I can cover it some how to protect cables if needed.
Is there any suggestions of where wires can run, easy routes to front and back?
Any recommendations if you have already done it
Thanks
12th May 2020 9:53am |
