![]() | Home > In Car Electronics > Install Advice |
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 303 ![]() ![]() ![]() |
There are a couple of options :
AVH-Z7200DAB has 3 RCA Pre-Outs (F, R & Sub) so one option is to use the Focal IBus 2.1 Subwoofer with the front Pre-out and power the front speakers and the sub it’s self, and get a small amp for the rear speakers (since the head unit has no onboard amp/output). The better and more flexible option may be a 5 channel amplifier, with all 3 pre-outs as the input, then F, R and Sub output, this would allow you to coarse tune the system using the amp controls and fine tune via the AVH-Z7200DAB’s 13-band Graphical EQ. If your wanting the best from the HU, amp, speakers and sub, I would certainly upgrade the standard cabling, (not nuts with foamed PTFE jacketed solid silver shielded with pure unobtainium at £5000 per meter) but a more like Cambridge Audio Symphony 300 (from £2.20/m) is a flatter cable so easier to fit. ![]() Good RCA leads are also important, don’t have a great head unit, nice amp, great speakers and cables and use low grade leads to connect the amp. Spent two years part-time in a car audio shop /installers while at university. Leared a little about fitting and in car entertainment, everthing from mild upgrades to 2 x 15" subs, and 4 amp custom build in an M3 convertable ![]() www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
trailbear Member Since: 14 Sep 2016 Location: Scotland Posts: 405 ![]() ![]() |
Oh blimey, this is starting to sound quite a bit too technical for me!
So does that mean that I need the H.U. front and rear speakers, 5 channel amp and a separate subwoofer? I am trying to keep everything pretty much as discreet and hidden as I can and thought about placing the Sub and now Amp under the 2nd row seats so as not to interfere with the already limited space in the vehicle. Is there a Sub and Amp ( not too big ) that you would recommend that would be able to be placed in the area that I had thought about. I am not really sure of anywhere else in the vehicle that would accommodate the items mentioned and am open to suggestions. Thanks for the info so far. |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
on the subject of ISO connectors I just updated my LR standard CD radio with a Kenwood head unit, it was plug and play my car already had ISO as built in 2011
only issue I have is the LR radio would come on without the Key for a limited time the Kenwood does not support this function! DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
The reason it's quite complicated is the lack of on board amp for the HU , so Yes you may need HU, F Speakers, R Speaker, Sub and Amp (plus any caleing, fuses, and ISO adaptor... Finding a Hu with onboard Amp make life a lot simpler - The Onboard Amp runs the Rear speaker, the Focal Sub/Amp combo then runs F Speaker and Sub - you elimate the 5 channel amp since its intergated into the Sub. There is a third option - ignore the rear speakers : the Focal Sub/Amp combo runs F Speaker and Sub, as a staring point, then if you feel you need rear speakers/fill add them at a later date with a small 2 channel amp. How often do you carry passangers? How important are the rear speakers, most of the audio is stereo so a 2.1 system would work fine, some of the best audio cars I've seen are heavy front bias with no rear fill. (Driver/Front passager bias) High frequency (tweeters) are very directional - you can tell where they are very accuratly, mid freq. less so, about the right area is good enough, low freq. (sub) can go almost anywhere since it is difficult to detect direction (to the human ear) thats why it often ends up as a sub box in the boot. Equipment Recomendations - I'll have to have a look.... Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
Excellent, That is starting to make a little more sense.
I look forward to whatever suggestions that you can make. |
Answer possibly found : https://www.alpine.co.uk/p/Products/powere...s45/pwd-x5
PDW-X5 - Amped sub with 4 channel amp built in - so thats F, R & Sub in one box. Not quite as flexible or upgradeable as seperate amp/sub combos but for ease and simplicty it hits your requirements - plus setup is done on your laptop connected to the box, no fiddling with pots hidden under the seat on your back trying to adjust the crossover points Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
Thanks very much for that.
That looks like the way to go for simplicity and coupled with the advice that you have already given, I think that with a little concentration and patience that I think I may be able to achieve the install i was looking for. That's why I think this forum is such a success in that there is pretty much always someone who can give advice or assistance with pretty much anything and everything Land Rover related. By the way, i've had peek at your website and that is some very impressive photographic skills on display. I am still learning to find my way around mine at the moment. |
No Problem - shareing knowlege is key pillar of any forum.
Thanks for the kind comments about my images. If you were closer I could have provided some photographic tuition, but my advice would be; 1 : Shoot, shoot lots, just like in any field, the more you practice the bettter you get, especialy now that you not paying for film, devloping and printing. 2 : Join your local camera club, yes it may be precious hours in an evening, but you will learn lots with the right club and members. Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
Thanks for the tips, it's something that I am definitely going to work on.
Now that I have a little more time on my hands and more plans I would be foolish to pass up the opportunities. |
