Home > Puma (Tdci) > 110 Van internal cab roll cage
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
Having spent ages during the lockdown watching Russian dash cam footage on YouTube, I have become more aware of just how vulnerable vehicles can be to rolling over.
Given that the most substantial part of the Defender's cab is the driver, is there a roll cage or roll-over bar available that I could fit inside the cab of my 110 van?
Having searched on-line, I don't really fancy an external one, both for the appearance and the problems of keeping the bodywork clean underneath it.
Thanks as always folks.
Post #829813 8th May 2020 6:50am
jst
plenty of options from stand alone hoop to full cage made to measure.
a single hoop is better than nothing, but ideally it needs diagonal stays back to chassis and a cross piece.
I picked up an internal hoop on here 2nd for £130, safety devices.
also look at north off road and try protection and performance Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #829814 8th May 2020 6:55am
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Or go bespoke like mine ?
Post #829815 8th May 2020 7:10am
Joe the Plumber
Thanks folks. I like the idea of combining it with a cargo barrier as I've already got one of those, so it shouldn't take up that much more room.
Post #829822 8th May 2020 8:57am
Harry.O
Following this with interest, I'm looking for something similar for my 110 HT.
Daisy 90 can I ask who built your internal cage and also where you got the loom extension to relocate the ECU? 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #829823 8th May 2020 9:22am
jst
I have an internal p and p cage hoop with rear stays attached, that could be ground off available if people are interested. Mounts to floor of rear load area, would need chassis plates fitting underneath to be structurally sound. Ie played welded onto chassis to then bolt this too. Same as any practical hopp would have rather than a cosmetic hoop. Open to offers. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #829830 8th May 2020 10:09am
camelman
I had an SD internal external cage on the 110 HT.
Post #829850 8th May 2020 11:33am
Daisy90
You have a p.m Thumbs Up
Post #829888 8th May 2020 2:03pm
Daisy90
Bolts through the floor and on the chassis so should the job if I’m ever unluckily enough to use it,
The top diagonal mesh is also removable for longer things
Post #829900 8th May 2020 2:58pm
jst
Sorry what mount is that to the chassis? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #829968 8th May 2020 8:33pm
Daisy90
It’s where the cage is sandwiched through the floor, so hopefully any impact will be taken on the chassis not just on the thin bodywork
Post #829971 8th May 2020 8:47pm
jst
Yes, I get that, I meant make, is it standard supplied? Only seen and fitted them to chassis plates before, usually legs come in closer to floor pan rather than seat box. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #829977 8th May 2020 9:21pm
Daisy90
Aha, I understand now,
The whole cage n mounts was made from scratch and fitted
Post #829985 8th May 2020 9:36pm
Daisy90
My criteria and reason for fitting it in the first place was “just in case”
I’d had a few close ones whilst in wales and was heading off to the Pyrenees , the truck was never going to be used for comps or knowingly dangerous days out / play days
I wanted to keep as much space inside the vehicle available for storage etc
Post #829986 8th May 2020 9:40pm
