LR90XS2011
8th May 2020 7:28am |
Finchy13
As LR90XS2011 says it a one shot grease. 1 sachet per CV, the LR part number is STC3435. All the main suppliers have it, i.e. Bearmach etc but if you want the genuine LR then I found some on ebay.
The LR sachet has no specs on it and just says "High Temperature Grease 375ml". Its less viscous than most greases however.
You may find also your swivel housings in fact do not have drain plugs and only filler plugs. Not sure when the change point on the Puma's was. LR's idea is they are sealed for life My 2013 has no drain plugs and the only way I can see to swap the grease is to actually remove the swivel housing and CV completely... Then again the grease is supposed to be good for life providing it doesn't end up in the Diff or on the tarmac via the seals
8th May 2020 10:36am |
