Home > Tdi > Front and rear anti roll bars
lb73
Wales
When I bought my 99 300tdi csw it never had the roll bars fitted - I presumed they had been removed by the previous owner. Anyway I’m thinking I’d like to refit them so I checked out the mounting points the other day, the back ones are fine and look ready to have it refitted. However on the front the brackets are present on the axle but there are no mounting points on the chassis like these
The only mounting points I can see is these - sorry for the poor photo, which I presume are for something else, as they look set to far back.
I know you can buy the weld on mounting brackets to weld to the chassis, so that one option, but was just wondering the reason for it, was there a different front anti roll bar set up on earlier models? Thanks in advance. 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2002 Dax Rush 3.9 V8
2012 Audi A3 tdi
2020 Renault Kangoo electric
Post #829428 5th May 2020 9:29pm
Litch
I don't have anti roll bars on my 90 but my new (300TDi) chassis has them fitted, I assume these are the front ones you are referring to (just behind & below the engine mountings)?
 ONE LIFE, GET IT!
Post #829529 6th May 2020 5:43pm
lb73
Wales
Yes they are the ones, think I might order the weld on brackets, liking the gav chassis cheers. 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #829572 6th May 2020 9:53pm
Oldowner
The brackets were standard fit from 94 onwards so yours have been cut off for some reason, or the chassis has been changed.
The weld on brackets are fine, I’ve fitted a few of them years ago when upgrading pre 300tdi chassis 90s to antiroll bars,well worth doing.
Post #829598 7th May 2020 4:06am
lb73
Wales
Thanks for that, presume they have been removed for whatever reason. Will get a weld on set ordered. 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #829603 7th May 2020 6:48am
Mountain_man
Wales
If you need antiroll bars, rather than pay through the nose for a set of defender ones, it is worth noting the tdi Discovery ones fit just fine (and are usually thrown in the scrap). You will need the 4 bolt U clamp for the rear from a defender though as the disco only used a 2 bolt clamp. The fronts are the same.
Post #829632 7th May 2020 10:18am
lb73
Wales
Cheers for the info, will get looking. 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #829992 8th May 2020 10:42pm
Mountain_man
Wales
Post #830173 10th May 2020 12:00am
lb73
Wales
Thumbs Up 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #830387 10th May 2020 10:24pm
Procta
Laugh was, when i did this to my TDI, I only had the brackets for the front, Me and my mate later fitted the rear. We had to weld the rear brackets on the back. So looks like they must have added the full works on the later 300s, Mine was a 97 plater.
Funny thing was, it was the very last upgrade i did and never even got the use of Rolling Eyes Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #830576 12th May 2020 12:25am
