Home > Maintenance & Modifications > Rear brake disk shot and new stub axle??
bear100
So I wanted to just change my rear pads to compliment my new LOF powespec front callipers, disks and pads.
It soon became apparent that I needed more bits!
Look at the state on this disk! The other side wasn’t as bad
I’m sure it was a Bearmach disk fitted 2 years ago with probably about 6k miles traveled.
So a new order to Luke at LOF for a set of new discs and a pair of callipers because the pistons are shot.
While all the tools were out I stripped down the both rear assembly’s ready for the new to arrive and noticed one of the stub axles had some marks, do these marks suggest a new stub axle is required? Not sure what constitutes a new one is needed?
 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #828883 2nd May 2020 2:22pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
That’s will clean up with a bit of emery cloth, it only looks like fretting corrosion.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #828932 2nd May 2020 6:56pm
bear100
Cheers Will
I thought as much but didn't want to guess and put it back together, ive got some light sand paper and will give it a go tomorrow.
Thumbs Up Thumbs Up 2023 Defender L663 V8
Post #828940 2nd May 2020 7:39pm
jst
Stub look workable where bearings sit, are there grooves where the seal goes on the shoulder or just shiny? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #828945 2nd May 2020 8:05pm
bear100
It’s just shiny, should the bearing fit tightly on the stub and not spin? 2023 Defender L663 V8
Post #828949 2nd May 2020 8:31pm
jst
The inner race shouldn't turn. The Mark's you have are from the previous one rotating or the race getting hot and the heat being transmitted through the inner race to the stub.
If it's not marked the stub or will be fine, it doesn't have to be cleaned off to function either. I would clean it off though. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #828967 2nd May 2020 10:11pm
As a rule of thumb, if you can feel damage on the stub axle with your eyes shut replace it, if it is purely visual it should be ok, unless there is severe "blueing" indicating heat damage.
The inner races should slide smoothly on the stub with zero play or movement if waggled. Usually it is wear on the surface upon which the oil seal runs which determines the need for a new stub, in Series days when proper engineering still ruled the day these rings were renewable (and the wheel bearings were a lot bigger!) but in this era of "value engineering" the stub axle is one-piece and it's no longer possible just to do this.
Post #829004 3rd May 2020 9:44am
