Home > Maintenance & Modifications > Wheel arch eyebrows
CarMan
Wheel arch eyebrows
Thinking of replacing mine on the soft-top as one is a mis-match Rolling Eyes
Any suggestions for suppliers at reasonable cost Question
Think I would prefer old school matt rather then the shinier Puma type, but any recommendations welcome
Assuming genuine are ££££
Thumbs Up Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #828517 29th Apr 2020 5:22pm
Green Machine
Pre-Puma Matt Black eyebrow mouldings:
Front RH: RRC3043
Front LH: RRC3044
Rear: RRC3045
Puma Black Plastic Not Painted eyebrow mouldings:
Front RH: MRC9378
Front LH: MRC9377
Rear: ALO710010
Idea of supplier options / cost variation here 2005 Td5 | 90 Station Wagon | Tonga Green
Post #828535 29th Apr 2020 6:23pm
CarMan
Thanks, change of plan if they are £50-£100 each Shocked
Had seen Terrafirma matt black set of four for £135
Post #828538 29th Apr 2020 6:27pm
Green Machine
There may well be other options (such as the Terrafirma ones you have found), I just did a quick Google on the part numbers Thumbs Up 2005 Td5 | 90 Station Wagon | Tonga Green
Post #828539 29th Apr 2020 6:30pm
Harry.O
I would avoid the Britpart ones personally, the shiny set I ordered a few years ago were of a hard and brittle plastic rather than the flexible OEM versions, several have already shattered having been rubbed down trees. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #828626 30th Apr 2020 9:16am
CarMan
Thanks Thumbs Up
I was hoping for a recommendation to avoid exactly the type of situation you find yourself in
Post #828694 30th Apr 2020 4:58pm
