Home > Maintenance & Modifications > Swing away spare wheel carrier
gilly1969
Can anyone help me with the positioning of the wheel plate that is fixed to the rear door? This is what the piston is attached to which is then attached to the swing arm. It came with instructions from Britpart but there's no way of knowing how to position the wheel plate on the door. I don't want to be drilling holes all over the new door I've just fitted. Cheers.
Post #828046 27th Apr 2020 8:06pm
Paul1275s
United Kingdom 2003 Defender 110 Td5 SW Belize Green
Which type of wheel carrier have you got? I fitted an military surplus Mantec to my 110 and manufactured a plate that mounts onto the six original spare wheel carrier holes on the rear door, then I welded the Mantec wheel plate to that. 2003 Defender 110 TD5 SW
2003 Caterham 7
2006 Mini Cooper GP
Post #828152 28th Apr 2020 9:38am
gilly1969
I think it's Britpart - at least that's the branding on the box. The wheelplate has pre-drilled holes to suit all Defender/Series variants. Mine's a 1987 Defender but I replaced the original safari door with a new one at the weekend, so there are no corresponding holes to line up the wheelplate. I'm thinking I may have to put the swing arm on first then offer it up to the wheelplate held against the door to mark where the holes need to go. I just wondered if anyone had some more detailed instructions/measurements I could refer to than those supplied in the box.
Post #828229 28th Apr 2020 2:27pm
Can you not measure the holes on your old door? Darren
Post #828231 28th Apr 2020 2:36pm
gilly1969
Checked that. They don't correspond with any of the holes on the wheelplate either!
Post #828234 28th Apr 2020 2:38pm
Harry.O
There are some instructions here but sadly no measurements to assist.
https://www.paddockspares.com/downloads/pm132.pdf
Is your new door the later one piece type? If so then there should be holes on the inner frame that would correspond, they certainly did on mine. I used them as a guide to drill pilot holes from inside then drilled these holes larger from the outside inwards.
If you would like some measurements then let me know, I have the same carrier as the one in the instructions. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #828238 28th Apr 2020 2:59pm
Hmm, strange. I've got one of thee carriers in a box in the garage, in my project queue. I'll take a look at the plate later. If the holes line up with the standard carrier on my 110 (I hope it does!) then I could measure those for you. Darren
Post #828239 28th Apr 2020 3:01pm
I have that same carrier too, with the same instructions. However, the door mounting plate is different to the one shown and I suspect it's been amended to match the later wheel carrier holes. Darren
Post #828240 28th Apr 2020 3:03pm
Mdm
fir the new carrier and mark the door is the simplest way forward.
depends what door you fitted and what teh carrier make is
Post #828241 28th Apr 2020 3:08pm
gilly1969
It's chucking it down so I'm not going to the shed to check until it stops. Thanks for all the advice. I'll take measurements if anyone has them. I'll end going for a combination of offering up and measuring off. Nothing is ever straightforward!
Post #828245 28th Apr 2020 3:22pm
Paul1275s
What does the inner frame of your new door look like? Does it not have the six holes?
I can measure rough locations of those if required 2003 Defender 110 TD5 SW
2003 Caterham 7
2006 Mini Cooper GP
Post #828247 28th Apr 2020 3:32pm
gilly1969
New door pic.
Post #828251 28th Apr 2020 3:58pm
Paul1275s
This was the back of my old one, you can see the reinforcement where the wheel carrier bolts.
2003 Caterham 7
2006 Mini Cooper GP
Post #828286 28th Apr 2020 6:48pm
gilly1969
Sorry pic didn't attach last time. My door looks nothing like yours. Having said that the old one I took off didn't look like yours either.
Post #828290 28th Apr 2020 6:57pm
Paul1275s
Ok, earlier type door, mine's a 2003. Looking at where the smaller plate is on my rear door the holes on it should go through the central vertical frames on your door. 2003 Defender 110 TD5 SW
2003 Caterham 7
2006 Mini Cooper GP
Post #828297 28th Apr 2020 7:11pm
