![]() | Home > In Car Electronics > TMD Billet Light Fitting |
mwestcrew Member Since: 09 Dec 2019 Location: South Warwickshire Posts: 289 ![]() ![]() ![]() |
Try it one way, see if works. IF nothing try the other way. Light Emitting DIODE, current only passes in one direction. 2011 130 Utility Body
2005 110 Van |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6725 ![]() ![]() ![]() |
Amazing there are no instructions with it
timthepom Member Since: 12 Jul 2019 Location: United Kingdom Posts: 29 ![]() ![]() ![]() |
Yes, I agree, was a bit surprised. No doubt someone in here has fitted one though
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022 ![]() ![]() |
Pretty sure brown will be live and white Ground. Best to check it though, Normally such colours will have a little tag on the live to denote polarity, sometimes they come off or of course may never have been any..
If you have a 9V battery around, you can probably try that to find out its polarity as most 12v marketed items are usable between 9V & 16v. Being LED it should light up no problem. Might save you having to take the seat base and panel out or having to make any temp wiring just to find its polarity on the LR battery. ![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
no instructions at £ 90 - with instructions £120
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2528 ![]() ![]() |
![]() 2015 Discovery 4.5 Black pack Firenze red XS |
They're not the only ones, unfortunately. I've fitted quite a lot of reasonably expensive stuff that hasn't come with any instructions - most recently, Nakatanenga and Safari Equip spring to mind. I suspect that a lot of these what are really cottage industry type companies, start off as engineers and think that all of their customers are the same. Darren
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2416 ![]() ![]() ![]() |
Expensive shiny things don't need instructions.
Apparently. Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 737 ![]() ![]() ![]() |
These companies obviously assume that if you can afford their products, you employ a man who looks after the cars in your garage and knows how to fit them.
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4338 ![]() ![]() ![]() |
The Gwyn Lewis, Mud Stuff and Safari Snorkel stuff I've had has always come with good instructions
Wouldn't be beyond unreasonable to actually fit a connector on it (they are available)
Yes, didn’t even come with correct connectors fitted for “plug and play” which wouldn’t have been hard to do given the price. Just two bare metal wires. Hmmmm
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18031 ![]() ![]() ![]() |
The Optimill equivalent comes with instructions and a connector!
