![]() | Home > Off Topic > Anyone bought one of those cheap 63L cement mixers off eBay? |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3357 ![]() ![]() ![]() |
If it's only for one job I would hire. We got one for £20 per week delivered/picked up.
Although you could buy one and then stick it on eBay when you're done? WARNING. This post may contain sarcasm. |
Chugga90 Member Since: 07 Sep 2014 Location: Bucks Posts: 209 ![]() |
Have always used belle mixers. Not sure if the same applies to lower cost options, but they mix better fully loaded rather than part loads.
If you are mixing lime mortars you could mix a few mixes and store as they will keep for a long time if kept covered if it’s lime putty. If you are using hydraulic lime this would keep mixed for around a week depending on weather conditions and kept covered. Also it remixes more useable the second time around. One possibility for small scale use is using a plasterers type paddle mixer and a gorilla tub, takes up less space to store it, easier to clean than a mixer, ie less mess generated. Just make sure you gauge the materials for each mix to get a uniform colour match. Good luck and hopefully it is not too warm to dry out your work area too quickly. ![]() |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4318 ![]() ![]() ![]() |
I've got one that looks just like this, but it's all black:
https://www.amazon.co.uk/Portable-Electric...RGSC4W6FFQ I can't recall what wattage it is, but I've run about 20 bags of ready mixed concrete through and it's still working fine. Well made it is not, but for occasional DIY use it's been ok. I did think about hiring, but my projects always take weeks and I don't work fast, so it quickly becomes uneconomical. 2007 110 TDCi Station Wagon XS |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1343 ![]() ![]() ![]() |
Thanks for the feedback everyone.
I ordered a 500W Handy mixer this afternoon from Mower Magic, only to get a message saying they didn't have the one in stock that they thought they had! So back to square one. I've decided to go for something similar to the one you linked to Bluest. I figure a 500W motor has got to be e better bet than a 220W one, especially if I don't fully load it. The entry level Belle mixer is out of stock everywhere. I guess with most of us on lock down, DIY projects will be on the increase. |
