Home > Maintenance & Modifications > Recommendations for a brake bleeding kit
Co1
Is there any kit out there that people would recommend, or is the best way still a 2 man job and a bit of hose at the callipers?
Col
Post #826433 19th Apr 2020 6:58pm
TD5Neil
If you have a compressor the vacuum ones that run off the airline work well. I have a sealy vs20. They are around £20 on Amazon or eBay.
Post #826438 19th Apr 2020 7:10pm
Bluest
Ive got the Sealey VS820 which I really like Thumbs Up 2007 110 TDCi Station Wagon XS
Post #826440 19th Apr 2020 7:25pm
jst
Eazibleed that works off tyre pressure. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #826457 19th Apr 2020 8:41pm
Devon-Rover
United Kingdom 2014 Defender 110 Puma 2.2 USW Aintree Green
I've had no problems with the Laser one
https://www.screwfix.com/p/laser-manual-brake-bleeder-2ltr/6819j
Thumbs Up Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #826464 19th Apr 2020 8:52pm
Roger
United Kingdom 2007 Defender 110 Puma 2.4 SW Java Black
To be honest, there is no reason to brake(!) the bank, one man bleed kit from halfrauds works fine. The one that comes with it's own receptacle is about £5/6, you'll need to rest it on something as the hose isn't long enough to put the container on the floor. The kit allows you to slip a flexible tube over the bleed nipple, loosen nipple and then just slowly pump the pedal.
Did the motorbikes yesterday and was supposed to do the Defender today but took the dog on a long walk for my daily exercise instead!
Post #826475 19th Apr 2020 9:16pm
Litch
If you want cheap and reliable then you can't go wrong with the traditional Eezibleed kit, I have had one for nearly 30-years and it makes bleeding a simple 1-person operation. Thumbs Up
If there is a downside with the Eezibleed however it is that you have to be close to a source of air and I found that it often meant rolling the vehicle a couple of feet either direction to get the O/S F tyre valve at the 12-oclock position (otherwise the line would not quite reach), also there was also the possibility that tyre pressure could have dropped a couple of PSI meaning a top-up was required.
More recently I bought a Sealey VS820 and it totally does away with the (slight) downsides of the Eezibleed system.
Yes it is more expensive but it is totally independent and after a few pumps to pressurise the bottle off you go just as quick & easy as with the Eezibleed but without having to reposition the vehicle (or unload the spare) or top up afterwards. Very Happy ONE LIFE, GET IT!
Post #826586 20th Apr 2020 5:16pm
Mini Landie
United Kingdom 2003 Defender 90 Td5 HT Belize Green
+1 for VS820. I’d been using an Eezibleed on other cars, but I’d planned to do the Defender this weekend just gone and did NOT a fancy lugging the spare about, so bought the VS820. Makes life sooo much easier, and much easier to control the PSI.
Post #826598 20th Apr 2020 6:22pm
Co1
Thanks all.
Post #826615 20th Apr 2020 7:09pm
sako243
Ummm, piece of pipe and a jam jar? Rolling Eyes
Honestly I've tried the eazibleed and been waay more successful and quicker with a jam jar part filled with brake fluid and a pipe that goes onto the bleed nipple. Can be done single manned as well. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #826655 20th Apr 2020 8:57pm
TD5Neil
That Sealey VS820 looks really useful as a stand-alone without needing a compressor or tyre.
Post #826829 21st Apr 2020 4:49pm
TD5Neil
Post #826830 21st Apr 2020 4:50pm
