Home > Maintenance & Modifications > Heater control fix Puma
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
With the numerous times the dash has been in and out, the heater control for selecting between lower/windscreen and dash vents wouldn't go past lower and windscreen.
Looking online for a new switch assembly, checked the price and then ignored that and figured i could maybe fix it.
After removing the switch and selector assembly i found the dial that adjusts the 2 cables which in turn adjust the output from the heater box had a piece broken off;
When you turned the dial past lower/windscreen the end of the cable left the track and wouldn't allow you to move it anymore.
I found a piece of plastic from the end of a track saw guide;
I shaped it to fit roughly
Then glued it into place with superglue and an accelerator. Once i had done this, i then used the dremel and a hot knife attachment on the soldering iron to shape the bend in the channel.
After that, i shored up the back edge of the track with solid adhesive/gap filling stuff so the issue wouldn't arise again.
Placed it all back together, re did the seals on the heater venting as they had persished and put the dash back in and all is good Thumbs Up
Lesson learnt that instead of paying £140 for a part, you can probably fix it yourself for no cost and a little time Very Happy
Post #826097 17th Apr 2020 10:46pm
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Thumbs Up
that’s what I like to see, fixed rather than replaced ,
Well done
Post #826109 18th Apr 2020 4:44am
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Well done.
Very much the Defender spirit applied there! Thumbs Up 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MT´s,
Recaro CS´s, anorak, wellingtons
Post #826110 18th Apr 2020 5:42am
Barneyboy
England 1986 Defender 90 2.5 n/a Diesel ST Nato Green
Great fix and just goes to show what can be done with a little perseverance and time Thumbs Up Paul
Post #826124 18th Apr 2020 7:44am
