![]() | Home > Td5 > please identify this |
davidblythe Member Since: 27 Apr 2019 Location: Cheam, Surrey Posts: 110 ![]() ![]() |
Bought this attached to my 110 a year ago and havent seen it elsewhere
anyone identify it and how it works ![]() Click image to enlarge ![]() Click image to enlarge |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915 ![]() ![]() ![]() |
yes, it's an aftermarket disconnectable anti-roll bar origingally made by X-Engineering (now taken over by Foundry 4x4). The round item in the first photo is actually a freewheeling hub (as used on Series Land-Rovers) configured to release the ARB when disengaged.
The idea is that on the road the ARB is stiffer than a standard one to provide less body roll, but off road it can be disconnected to allow greater axle movement. They are generally reckoned to be absolutely terrible and you should remove it and give it to me for safe disposal as soon as possible! ![]() Actually it is a good thing to have if you do intend to use your Defender heavily laden on-road and also off road where maximum axle travel might be needed. Definitely a plus point on the vehicle. See https://foundry4x4.co.uk/index.php?route=p...duct_id=77 for more info. |
two settings 4*2 and 4*4
any idea which is what |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1490 ![]() ![]() ![]() |
4 X 2 = Disengaged
4 x 4 = Engaged, ie anti roll bar is connected and working. As already mentioned it's a freewheeling hub, normally used to disengage front axle drive. ![]() |
