Home > Maintenance & Modifications > Refreshing the rear crossmember
MarcusM
2007 Defender 90 Td5 HT Keswick Green
Just wanted to share a very satisfying job I did in the last couple of days giving the rear a refresh.
Used the Buzzweld kit which worked amazingly well and also brought the bracket of the mud flaps back to life.
https://www.buzzweld.co.uk/fxliner-1k-cros...g-kit.html
Only issue was I could have been better using the spray can as didn't get the most perfect surface finish!
 Keswick green 2007 Defender 90 TD5
Post #824214 9th Apr 2020 9:16am
markb110
Very nice, did mine last year.
A little tip as we all have time on our hands at present.
The mud flap bracket covers a drain hole in the sloped section of the cross member. Drill out a corresponding hole in the mud flap to let water and muck out.
Why Land Rover never thought of that shall forever remain a mystery..... Laughing
Post #824223 9th Apr 2020 10:21am
MarcusM
Great tip- will ge that sorted, thanks Mark Keswick green 2007 Defender 90 TD5
Post #824234 9th Apr 2020 11:41am
Adammacky
Looks much better, did you have any left over? I'm planning to do this myself but was wandering if theres much left to do any other areas that need tidying.
Thanks
Post #824275 9th Apr 2020 3:00pm
MarcusM
Thanks, to be honest you could do with another set if you wanted to other areas- I felt like I had just enough to do the crossmember and tow bracket below with one of each of the products. I bought 2 sets (4 cans) and did part of the front bumper, mudflap brackets and the rear crossmember bits here with none left over. Keswick green 2007 Defender 90 TD5
Post #824284 9th Apr 2020 4:04pm
Adammacky
Reckon this stuff would work well on a spare wheel carrier? Mine has alot of rust and needs refreshing
Post #825626 15th Apr 2020 8:53pm
MarcusM
Yeah for sure- I used the dual set on a few things works well- will give a matte finish though if that’s what you’re after Keswick green 2007 Defender 90 TD5
Post #825629 15th Apr 2020 9:02pm
Adammacky
What did you use to strip it back to the metal?
Post #825679 15th Apr 2020 11:29pm
MarcusM
I used a wire brush drill cup and it came off pretty well- I have heard of using a flap disk which I think goes on an angle grinder. I managed pretty easily using the drill though. This was when I started with it-
Post #825729 16th Apr 2020 8:46am
Hernia
Just stripped all the furniture off mine and gently went over with a 120 grit flapper wheel (only took a few minutes). Had been over with the brush cup previously, but was taking forever to get through the *good* paint that was left.
Post #825792 16th Apr 2020 1:13pm
Hernia
Post #825793 16th Apr 2020 1:14pm
