Home > Expedition & Overland > modifications / upgrades for africa
Outlaw1
England 2010 Defender 110 Puma 2.4 USW Santorini Black
Hi all , What modifications / upgrades would you do or indeed be necessary for trip to north /south .
I am only talking mechanically as i think actual fit out is personnel
Diff
Clutch
output shaft
Forgot to say puma 2.4 tdci 110 utility
or forget it and buy a toyota Big Cry
Post #824139 8th Apr 2020 5:57pm
Larger intercooler possibly to help with the heat.
Check prop UJ's, DM's splines and fluid levels etc. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #824145 8th Apr 2020 6:22pm
Personally I'd fit Ashcroft ATBs front and rear, with HD CVs in the front, and HD drive members. In the back I'd go for one-piece halfshafts. If this is too much, then at the very least I would make sure that I had a four-gear diff in the front axle, not a two-gear diff as fitted to many 2.4s, the two-gear diff will fail, you just can't tell when. (The main reason for the ATBs is that they are so much stronger - and cheaper - than standard LR diffs. They also offer much better traction).
I would also inspect the output adaptor shaft before setting off, and if it needs replacing either fit a standard one well-greased (with moly grease) or an Ashcroft upgrade. I would then still carry a spare and the tools to fit it. I would also probably fit a new clutch before setting off.
I would carry at least one and probably two Volume Control Valves, and a spare fuel filter head.
Post #824148 8th Apr 2020 6:32pm
