![]() | Home > Maintenance & Modifications > Front hub and stub axle confusion |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 834 ![]() ![]() |
Somewhere along the line my Ninety has been fitted with what I believe is an early Disco 1 front axle, I have come to this conclusion because the drive flange has a little stubby drive shaft attached to the inside of it.
I need to replace the hub and also the stub axle, I think the part numbers are as follows: Stub axle - FTC57 (available also in BP kit DA3193) https://www.paddockspares.com/stub-axle-ki...o-ja0.html Hub - FTC1457 which seems to be VERY expensive £406! https://www.brit-car.co.uk/product.php/864...er_classic Can I use the correct stub axle (FTC57) and a different hub? For example this one below https://www.paddockspares.com/ftc942-hub-assembly.html Or is there another way round it all? Many thanks. BORG - Bucks & Oxon 4x4 Response Group ![]() |
My research shows the early Disco I had the same hub arrangement.
The inner bearing race looks like it has been spinning inside the hub, a new race (and original) can be pushed in and out of the hub by hand also the stub axle shows sign of wear and damage. BORG - Bucks & Oxon 4x4 Response Group ![]() |
Bought some 2nd hand ones from a nice bloke on Ebay, two hubs, stub axles and stubby driveshafts for £50 delivered.
All in very good condition so I am happy. Just for info you can buy the stub axles new but not the hubs. Thanks for the replies. BORG - Bucks & Oxon 4x4 Response Group ![]() |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8375 ![]() ![]() ![]() |
Cool, good result Cheers
