Home > In Car Electronics > Realy connections
ARC99
Realy connections
Now I have the time I'm wanting to fit a relay to handle the power to several items that require an Ignition feed and not wanting to overload several fuses. I'm having a senior moment and need someone to confirm my thought process.
I have all the bits, cable, relay and fuse board to wire the individual items to, it's just the terminal numbers on the relay I ned help with.
If I remember correctly this is how it should go.
30, Power from battery.
85, earth.
86, Trigger from ignition live.
87, power out to fuse board. Don't make old people mad.
Richard
Post #823453 5th Apr 2020 11:01am
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
Richard, your memory has not failed you. You’ve allocated the terminals correctly. I’ve looked it up rather than rely on my own ageing memory Rolling with laughter
It may be prudent to include a fuse close to the battery on your power feed unless the cable run is only a very short one.
Im “currently” midst a similar project myself. Thumbs Up
Post #823457 5th Apr 2020 11:11am
ARC99
Bow down
Thanks Rockster I have fitted plenty in the past and never had to think about it. I thought about a fuse in the input side so I purchased one with an inbuilt fuse to protect the input side. Don't make old people mad.
Richard
Post #823462 5th Apr 2020 11:17am
rockster57
Thumbs Up
Post #823561 5th Apr 2020 8:42pm
