Home > Off Topic > Shed finds
Barneyboy
England 1986 Defender 90 2.5 n/a Diesel ST Nato Green
Shed finds
Hi I’ve been working in the allotment and decided yesterday’s job was to empty the shed as I needed some stored glass panes to fit to my greenhouse that had lost 4 panes over the winter, I came across these items and haven’t got a clue what they would have been used for so any help would be great please Thumbs Up
the top 4 items are I assume old hinges and they have been wire brushed and a coat of red oxide on they all had a B stamped on them and the number 5
Post #823395 5th Apr 2020 7:34am
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
Hmm, the first photo may have a clamp used on the bed of a milling machine and the thing with the spindle with a hole in it probably fits onto the vice in the third photo to tighten the jaws, the second looks like what's called a 'surface plate' (a specifically flat surface used in engineering, the last photo might also be one) and the next two are machine vices (also for machine tools or for a drill press, ie pillar drill).
Not sure on the other bits I'm afraid.
You can use some of this if you want to to clean them up:
https://www.bilthamber.com/corrosion-prote...nts/deox-c
Post #823397 5th Apr 2020 7:41am
Barneyboy
Hi joe the plumber Thumbs Up I believe they came from a local company Molins when it closed down a good few years ago Thumbs Up cheers Paul
Post #823399 5th Apr 2020 7:49am
ARC99
Have to agree with Joe, the two bits with large bolts are hold downs for either large drill of boring machine, you have one and a half machine vice's . The hold downs may have been for use one the one without holes. The large plates are indeed what I refer to as marking out tables, also called engineers flat surface, They should be completely flat and polished, all the corners, vertical and horizontal should be square. Don't make old people mad.
Richard
Post #823429 5th Apr 2020 10:06am
Barneyboy
Here’s one of the hinges I’ve cleaned up showing the B which I assume is a makers mark and a 5 which I assume is the size Thumbs Up
Post #823432 5th Apr 2020 10:17am
Barneyboy
Thank you both I will have a go at cleaning them up Thumbs Up cheers Paul
Post #823435 5th Apr 2020 10:18am
DSC-off
I think Joe's assessment is spot on.
The second vice looks remarkably similar to one I made as a first year apprentice many years ago. It was probably an industry standard trading exercise. Cool
Post #823436 5th Apr 2020 10:25am
ARC99
Just had a second look at your photo's. the item next to the hook looks as if it fits the vice with the slots it should have a fitting that allows it to slide back and forth but not come out of the slot almost like a T shape. Don't make old people mad.
Richard
Post #823456 5th Apr 2020 12:07pm
Procta
that hook might have been part of chain lift Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #823477 5th Apr 2020 2:04pm
The thimble on the hook clearly indicates that it was attached to a wire cable, probably a winch line.
Post #823481 5th Apr 2020 2:36pm
Barneyboy
Thank you all, I have sprayed any bits that should move and left them to soak I will see if they will move tomorrow Thumbs Up cheers Paul
Post #823506 5th Apr 2020 5:55pm
