Home > For Sale & Wanted > [For Sale] Genuine 12S Towing Electric Kit for 110 & 12N |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2200 |
Hi all,
I bought this kit ages ago with the intention of fitting to my 110 but i no longer require it. This is the genuine kit for TD5 110 and should also fit some TDCi vehicles and can easily be adapted for 300Tdi. It connects directly to the battery via two cables. There are two relays and a volt sensing relay which fit in the battery box. Strangely, although it plugs into the reverse light switch (for the ignition live) it does not pick up the reverse light feed from here. The VSR only switches the two ignition live feeds on when the engine is running rather than just the ignition on The cable loom runs right to the back where it also plugs into the two spade connectors on the original loom near the grey multiplug for the 12N circuits where it picks up the constant 12v feed and reverse light feed. The socket is a genuine LR one. The kit (STC50324) can be seen here https://rimmerbros.com/Item--i-STC50324 . Note: I don't have the mounting tabs for the relay holders or the metal bracket that holds the socket. The VSR has also been modified to have an adjuster so you can set the cut in/out voltage to suit your setup. Think £55 posted is fair. I won't be able to send until after the current lockdown situation is over but happy to hang onto it without any deposit for someone who is interested. I have a copy of the fitting instructions i can include too. I also have the genuine LR 12N socket to go with it (some wiring still on it but i have used the grey connector for my 13pin setup). Cheers Steve Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge [/list] 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
4th Apr 2020 9:23pm |
Danny Fireblade Member Since: 16 Mar 2018 Location: Hampshire Posts: 301 |
PM sent
4th Apr 2020 10:26pm |
Still Available 02' 110 TD5 Double Cab Rebuild Thread
6th Apr 2020 8:54am |
Bump £45 posted or £40 collected.
Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
22nd Jun 2020 11:37am |
V8Simon Member Since: 17 May 2016 Location: Prestatyn, Wales Posts: 137 |
PM Sent!
1984 90 V8 puma want to be. |
23rd Jun 2020 8:14am |
Now sold,
Thanks Simon 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
25th Jun 2020 1:27pm |
