Home > Puma (Tdci) > URGENT please check... |
G4sweep Member Since: 24 Sep 2010 Location: Paderborn Posts: 182 |
Only yesterday while trying again to source the leak through bulkhead into footwell did I hand tighten that bloody bolt securing the red lifting eye to engine block! Will have to have a look at pipe it was resting on to see if there's any chafage!! Sweep
2.2 110 XS SW ---------------------------- Gone; 08 D3 XS BN55 WPV G4 4.4V8 D3. O7 G4 Mongolian Recce 110 USW |
26th Jun 2011 10:09am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
did you find the leak ? 2.4 90 XS
26th Jun 2011 10:49am |
same happened 1 year ago........ I removed it..... simply.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
26th Jun 2011 11:08am |
In short, No. I only had a half hearted effort 30 mins before Missus was due to go out in 110! Bad admin on my part. I have seen the water ingress manual Zagato put up so will trawl through it when time permits to eliminate all poss leak points!! I have already used captain tolleys leak sealer under windsreen which appeared to stop one leak! although it may well be the same place that is leaking again... I have also removed one of the two bungs in heater air intake channel although it could be the heater box/bolts for this that needs sealing against the bulkhead.
I won't get emotional about it although I would like to find the leak once and for all to save the Missus getting wet feet Dgardel, that could be the way to go for me too Sweep 2.2 110 XS SW ---------------------------- Gone; 08 D3 XS BN55 WPV G4 4.4V8 D3. O7 G4 Mongolian Recce 110 USW |
26th Jun 2011 11:19am |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3247 |
Good luck Sweep !
I have had the windscreen to bulkhead seal replaced, new door seals etc. All seemed fine for a while but now the leak is back worse than ever It used to only leak when parked but now water is coming in whilst on the move. Back in the dealers on the 4th of July to see if they can find the problem - again - plus other warranty work on the paintwork. However, yesterday I found the paint flaking off the n/s gutter at the front. On closer inspection there appears to be hole in the sealer so maybe that is a clue as the water does appear to be coming from the area by the door. I didn't destroy to much having a look as I don't want to give the dealer any excuse for not repairing the gutter. Bob |
26th Jun 2011 12:58pm |
Hope you get it sorted Bob, as you say it's probably coming through the small crack in the gutter, doesn't need much excuse to find it's way in. Windscreen to bulkhead seal will be the avenue after going through water ingress manual stage by stage
Sweep Sweep 2.2 110 XS SW ---------------------------- Gone; 08 D3 XS BN55 WPV G4 4.4V8 D3. O7 G4 Mongolian Recce 110 USW |
26th Jun 2011 1:30pm |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
good call Grock .... just been out and checked mine - rattling round like a p***k in a bucket Guns and Landrovers .... anything else is irrelevant. |
26th Jun 2011 2:09pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4500 |
Yep,just checked mine and slightly loose. Slight turn of both retaining bolts sorted it. Nice call.
While I was doing it my hand was hitting off a grey covered piping coming out of a small 90 degree shaped plastic unit that was on the end of the unit that holds the 4 fuel feed pipes. I could swivel the plastic unit backwards and forwards. Is this O.K. or should it be tight? Seems to just clip on. Any ideas? 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai Last edited by spudfan on 26th Jun 2011 7:43pm. Edited 1 time in total |
26th Jun 2011 6:55pm |
galawaygreen Member Since: 16 May 2011 Location: Lincolnshire Posts: 132 |
Had the same fault on my, paint started flaking of the roof NSF gutter, once they started looking ended up with a complete respray on the roof. Also new bulk head seal as mine was leaking through the same area used to get puddles on both sides. |
26th Jun 2011 7:41pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
iv tightened my loads of times still comes loose but it still comes loose
regards steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
26th Jun 2011 7:48pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
I can't see the engine mount which side is it on
26th Jun 2011 9:43pm |
It is the bright red thing sticking up at the back of the engine. Good view of it from the passenger side. If you cannot see it, it's probably fallen off. 1982 88" 2.25 diesel
26th Jun 2011 9:54pm |
It's gone then one less problem.
26th Jun 2011 10:00pm |
Always look on the bright side. Glass half full etc. I like that. 1982 88" 2.25 diesel
26th Jun 2011 10:03pm |
