Home > Maintenance & Modifications > Shock absorbers
Danny Fireblade
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
Shock absorbers
On a bit of cross country this morning I heard a clunking that was unfamiliar. Upon inspection I found this:
With the other side looking like this:
Now I am wondering if its worth me getting normal bushes, poly bushes or even new shocks?? Does anyone have any recommendations of any of the above, and is this a job I could quite easily manage myself? Also there seems to be quite a few different types of bushes available so how do I know which ones I need?
Thanks in advance.
Post #823146 3rd Apr 2020 4:14pm
ibexman
Take them off Whistle
Post #823181 3rd Apr 2020 6:20pm
Mdm
std bushes or oe spec one . work well last well don't cost a fortune
easy job at home if the nuts come undone
Post #823259 4th Apr 2020 8:16am
Danny Fireblade
Thanks.
I have managed to get the nut off with the help of molegrips as the strap wouldn't work, and even then I feel like I have just done arm day in the gym Big Cry
I have just been looking at the two pics and it looks as if the side missing the bush only has one metal cup at the bottom, while the other side has a metal cup at both sides? Am I imagining that as only one cup come off the broken side??
I will order the bush, think OE will be fine, then fit that and look at changing shocks and related hardware in the future sometime.
I am hankering after Bilsteins and the Gwyn Lewis HD hardware, but thats for another day I think.
Post #823280 4th Apr 2020 12:04pm
markb110
Don’t forget to buy the turret retaining washer thingy, because if you don’t it’s is guaranteed to snap at least one bolt trying to get the nuts off.
Some companies do a heavy duty version.
If you do buy them then I can guarantee you won’t snap a single bolt....Sod’s law 101 Rolling with laughter
Post #823281 4th Apr 2020 12:09pm
Danny Fireblade
Yeah I was looking at new shocks (Bilstein B6 hopefully), Gwyn Lewis HD std height turrets, galvanised spring seats, front HD turret securing rings and rear HD spring retainers.
Have I missed anything out??
Post #823282 4th Apr 2020 12:17pm
Retroanaconda
At the bottom of the shock you should have two rubber bushes and four washers, two of the washers have a lip that locates into the hole on the mount. These are the inner pair. The other ones go on the ‘outside’ of the arrangement, i.e. one against the shock body and one under the nut.
Looks like the bush has worn and the lower of the two inner washers has taken a pounding against the axle mount and broken then fallen out. A pair of new bushes plus four new washers will see you right.
Post #823285 4th Apr 2020 1:44pm
Danny Fireblade
Thats what I thought, Thank you. Thumbs Up
I have ordered them so will see how easy they go back together when they arrive.
Post #823288 4th Apr 2020 2:07pm
isacs
I’ve just removed B6 from mine and returned to oe spec shocks
Post #823302 4th Apr 2020 4:44pm
D44 Turrets and HD rings on mine and OE dampers, bushes and springs with castellated spring isolators top and bottom front and back. Other than the D44 Turrets and rings all parts are Genuine. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #823311 4th Apr 2020 6:23pm
Danny Fireblade
Are the OE dampers really as good as Bilsteins then? What were your reasons for changing back?
Post #823329 4th Apr 2020 7:40pm
isacs
I just found them to crashy. So gone back to one spec to soften it down
Post #823370 4th Apr 2020 9:43pm
isacs
It was the alive comfort package, no comfort to be found
Post #823371 4th Apr 2020 9:45pm
