Home > Td5 > Squeaky seats
mustafasoleiman
United Kingdom 2003 Defender 90 Td5 XS CSW Indus Silver
Squeaky seats
Hello, my 90 TD5 developed quite noisy squeaky seats, probably the springs... As I have not become any heavier and don't plan on getting any lighter Embarassed , does anybody have a solution to the squeakiness?
Best
Alex http://instagram.com/h4vou/
Post #822554 31st Mar 2020 7:59pm
landy andy
Check that something isn’t broken. There are no springs in the seats. Thumbs Up
Post #822581 31st Mar 2020 8:52pm
It could be the seat back squeaking on its pivots.
Post #822622 31st Mar 2020 10:20pm
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Drive slower..... well it is the 1st April!!!! Smile Cheers Don.
Post #822672 1st Apr 2020 9:35am
ssg
If you can hear your seat squeaking in a Defender they must be bad! Rolling with laughter
Try firing some WD40 under the seat, that should sort it. Thumbs Up
Post #822723 1st Apr 2020 1:41pm
Harry.O
I'll be interested to hear how you get on with this, my driver seat squeaks when you lean back hard and the passenger base squeaks on every pothole/minor bump but only with a passenger in it, it's something I've been mean to fix for a while. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #822725 1st Apr 2020 1:47pm
landy andy
Check bolts are tight.
Post #822729 1st Apr 2020 2:03pm
DonH2000
Turn the stereo up...... I am not helping am I Confused Cheers Don.
Post #822743 1st Apr 2020 3:50pm
Outlaw1
England 2010 Defender 110 Puma 2.4 USW Santorini Black
Try taking one bolt out at a time but replace before removing another Hopefully find the squeak by elimination
Post #822745 1st Apr 2020 4:02pm
4RF RDS
In my experience a squeak in a seat is usually the pivot area in board side near the cubby box. There is a spring there and it often moves ever so slightly and begins to creak metal on metal. Check it out and lube it but don’t use WD40 it is not good for this application as it is too thin. You can see the bottom of the spring (the tiny vertical bar under the horizontal pin). The other end goes up the side of the back. You may have to pull the upholstery to get at it there.
Good luck. Thumbs Up
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #822748 1st Apr 2020 4:25pm
mustafasoleiman
Sorry I could not hear any advise because of the noise and the radio too loud...
Just joking... god bless this forum and WD40... It was the hinge at the bottom of the back of the seat... both of them.
Thank you!
Post #823043 3rd Apr 2020 1:27am
Procta
give them a bit of copper Grease, or some chain grease. WD40 I think doesn't really cut the mustard at all. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #823045 3rd Apr 2020 1:33am
