![]() | Home > In Car Electronics > 8GB USB stick doesn't work in Puma stereo |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403 ![]() ![]() ![]() |
I've never really got into storing music on stealable devices, so for years I have just kept USB thumb drives in most of my vehicles with a collection of MP3 music dumped onto it as an alternative to whatever is on the radio.
I recently got a couple of small Transcend JetFlash 510 8GB USB2 drives for the two Defenders, having managed to lose one of the my old sticks and another one having gone phut. I need drives that are physically small to avoid damage to the socket from something sticking out from the dash, normal sized ones are quite vulnerable and also vibrate on rough roads. However - they don't work at all in the Puma stereo (a standard base-level factory radio-CD with a USB port on the front panel) and in my 300Tdi, which has an aftermarket stereo, they only work if you first turn the radio on, wait for the error saying NO DEVICE, and then unplug and re-insert the USB (and then it works fine). There is nothing wrong with the drives (I've reformatted them and they work perfectly in a PC) and nothing wrong with the stereos in either vehicle, as an older/smaller USB drive that I have in the Shogun works fine in both vehicles. I assume it might be something to do with either the size or format of the USB drives (I have a dim recollection that over 4GB, drives use some different formatting arrangement) but wondered if anybody could give me any insight into this please, or suggest any solutions? --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
Thanks. I've just checked and both are formatted with FAT32, so it isn't that. There are options to format them with exFAT and NTFS, but it sounds like that wouldn't help. I'm at a bit of a loss what to try next, except maybe a different brand of USB, not something I can get locally (not in a micro one anyway). ---
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3665 ![]() ![]() ![]() |
The one time I tried a USB stick with music on in mine, I had the same issues.
Be interested if anyone does have a solution. I just put it down to the wrong file format? |
The odd/annoying thing is, having reformatted it again, if you unplug the USB and re-insert it, it now works in the Puma as well, but power off/on and the error comes up every time, unless you physically remove and re-insert the USB. Once it's working, it is fine. Stupid fffin thing
![]() 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
T140 Member Since: 15 Mar 2016 Location: Ayrshire Posts: 180 ![]() ![]() ![]() |
had this problem in my last Audi, the unit would only work with cards up to 4GB maybe your unit is the same nobody is perfect but being Scottish is a start
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946 ![]() ![]() ![]() |
I wonder if it is to do with the format/file type that the music is stored as?
I've never tried using a USB stick, I just play music from mobile via bluetooth. Could be your other option? James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Thanks, I wonder that too. I just ordered a different brand of mini USB but the trouble is you can't get anything that small nowadays so I had to get a 16GB! If that doesn't work I'll have to go with using an old larger one and hope it doesn't get crunched... --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 ![]() ![]() ![]() |
mines a 16 gb and no problems thats on a alpine head unit
Got to the bottom of this having found an original Alpine manual to download.
The CDE-130R doesn't support more than 4GB partititions on a USB storage drive. One wonders where Land Rover managed to find a stock of radios so old that they can't access anything bigger than 4GB, presumably it was a cheap deal on 2003 factory clearance stock ![]() ![]() Click image to enlarge --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
.....and the solution, for anybody who may be interested, is to download a program called Partition Wizard and just make a partition slightly less than 4GB to store the music on, leaving the rest of the drive space unallocated.
It means wasting the balance of space on the drive, but it's better than not having one! --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
