![]() | Home > Maintenance & Modifications > Machine Polishing |
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 ![]() ![]() ![]() |
I think you would need to be very careful, if the paintwork has already been damaged by poor polishing then the paint may already be very thin. Maybe best to take it to a professional detailer and have the paint thickness checked 1st.
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2021 ![]() ![]() ![]() |
Gtechniq do a P1 nano polish which is very safe to use with a machine and can even be used by hand, excellent for swirls and holograms
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3726 ![]() ![]() ![]() |
Thanks Bear. What do you recommend as a polishing machine?
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2540 ![]() ![]() ![]() |
I'd second what Scoobeenut recommends regarding paint thickness. Problem is you don't know how much paint thickness has been lost due to previous machine polishing. Defender 90XS SW
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1652 ![]() ![]() |
rather than do it yourself and risk buffing thru the already thin paint i can recommend matt at revive over in Yorkshire.
https://www.facebook.com/reviveautocare.co.uk/ not sure if he is open but he can do mobile if you have a decent under cover area |
Thanks guys.
There’s loads out there just pick one designed for polishing with variable speed settings, I think I got mine from tool station for about £35. getechnic also do the application attachments.
Good luck ![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
zippo87 Member Since: 29 Mar 2019 Location: Moray Posts: 100 ![]() ![]() ![]() |
Good luck - once you start down this avenue it’s a slippy slope!! You’ll have an array of pads, polish of various grades - fillers, waxes, clay bars, detox’s and the likes!! Go for a finer polish and build your way up - you don’t want to burn through and do any damage - if someone’s already been there and you have no idea of thickness I hope it’s not too severe. I used to have a black beemer, some of the hardest paint ever - the landy is considerably softer, and even a light blow over with a fine polish and micro fibre cloth and some poorboys black hole provides a grand finish! Enjoy this journey!!!
Thanks all. I don’t think that whomever did the polish has gone too deep, it looks like they literally spent 30s on the panel and whipped across as the swirl marks are long. Classic dealer quick polish before sale.
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921 ![]() ![]() |
I wouldn't let the dealer wash my van when it was in for servicing. He said 'But our cleaners wash those £70,000 Jaguars out there' and I thought to myself, yes, and they're all covered in swirl marks.
Being white, mine's not too bad, although there have been occasions when I can't be bothered to wash it 'properly' and it's just had a hosepipe and microfibre, but if the virus continues, it's going to get the clean I always intend to give it but somehow never quite manage. |
There's lots of good videos on YouTube regarding machine polishing, some amazing results can be had!
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 798 ![]() ![]() ![]() |
Its not too hard to do in fairness - so long as you are not after a show quality finish- it gets far more complicated and multi stage from that point.
When I worked at a small VW dealer we used to regularly have to machine red and white cars due to the issues with the paints oxidising. We generally used couple of different pads and grades of compound- then a polish, then a good quality wax, then a gloss protector/sealant. key thing was to always keep the panels/pads wet- I understand that the folk who do detailing go into special lubricating fluids- but we just used to ensure we kept moving across the panels and kept it damp with water. Regards Chris |
BobT Member Since: 13 Jan 2017 Location: North Yorkshire Posts: 110 ![]() ![]() ![]() |
I use one of these, fantastic.
https://www.theultimatefinish.co.uk/meguia...isher.aspx |
Just had mine main dealer serviced and said the same. I’ve just spent two days giving mine that clean and still got the roof to wax. It looks almost as good as when it came out of the showroom. |
