![]() | Home > Puma (Tdci) > HELP! Shut off noise |
| Tanndoktorn Member Since: 18 Jan 2020 Location: Oslo Posts: 17
I'm struggling with my defender puma 2.4 2007.
What is the sound after I stop the engine on the video? It's been there since I bought the car quite recently, but so far only when I stop the car. Now I can sometimes hear it while driving too. Normal or fu ... ked?! It does not sound good .. Video: https://www.icloud.com/sharedalbum/#B0TGVfZ2vGvDl9P |
| G4UJS Member Since: 20 Jan 2019 Location: Shropshire Posts: 226
Its the EGR Valve, they are supposed to do that!
Cheers Rob |
Aaah .. Just what I wanted to hear ! 🙏😊
I've remapped the ecu and was told the EGR was blanked at the same time (software blanked?) Do I need to blank the egr mechanically too? |
| Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3892
Hello
The garage that did my remap, coded it out of the ECU and also put a physical blank over it (like a small metal plate) Sounds like your ECU still thinks it's their otherwise it would not clatter... Mine was getting very noisy like embarrassing when I turned the car off... |
| hopeydaze Member Since: 11 May 2011 Location: Bath Posts: 30
My ECU sometimes makes the noise when I change gear at low speed. Can I ignore this, or will it get progressively worse until the vehicle stops running or goes into limp mode?
I’ve looked an YouTube videos and it’s clearly a pig to replace/clean. |
| DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2067
Probably EGR remapped out and blanked, but cleaning cycle has been left on to keep the mechanism working?
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2541
As stated above it’s the EGR going through a cycle to ensure the open and closing mechanism is cleared of fresh carbon. It does not do it every time you stop the engine, but should do it most of the time. So hearing it is a positive sound I listen for. Not hearing most times you switch the engine off likely means you have a malfunctioning EGR, which will likely mean Diagnostic Trouble Codes will follow (P0401) , then the Malfunction indication Lamp (MIL - yellow engine symbol) illuminating and engine going into limp mode. Changing the EGR On a 2.4 is not technically difficult, just real fiddly as it’s difficult to get to all the fittings. On the 2.2 it’s even more fiddly to get to the two bolts, two nuts & studs and two coolant pipe clips. I replaced the EGR on my 2.2 as had the above symptoms. On the 2.2 the OEM part used by LR, stamped FOMOCO as it’s a ford part is actually made by pierburg (has their part number on it as well). So sourcing a pierburg valve directly meant it cost £100 inc delivery. Lots cheaper than from landrover and it’s exactly the same part. I had to replace mine at 51k miles, some last longer, some less. It all depends on your normal driving conditions.
