Home > Off Topic > Isolation projects advice needed.
ARC99
I need to, occupy myself for the next 12 weeks as an at risk person and have spent the last couple of days thinking of things I could do to pass the time away.
One thing I have been meaning to do for years is to scan all my old 35mm negatives onto disc or similar storage device.
I did start doing this some years ago and went through two scanner devices in a short time which taught me not to buy cheap.
So here is the thing as I cannot go out and physically check things out I am looking for advice on what I can buy over the net that is reliable and reproduce the original quality.
I have checked the web and noticed that some look cheap and nasty and have low ratings due to quality of the produce and that that this and that break.
I'm not looking for a flat bed scanner.
So does anyone have any serious suggestions Don't make old people mad.
Richard
Post #820137 18th Mar 2020 8:53pm
Pat
Wales
This and something similar from Nikon, were the first choice for many back in the day. Still got mine. Now fetching silly money on eBay because the lens is sought after for some other application that escapes me.
https://www.imaging-resource.com/SCAN/KM5400II/KM5400IIA.HTM
http://www.photographyreview.com/product/d...-5400.html It started with a kiss, never thought it would come to this.
SIII CSW Safari, limestone, (JAC 914N). Where is she now?
It's not a car, it's a way of life!
Post #820141 18th Mar 2020 9:08pm
Pat
Wales
https://www.closeuphotography.com/minolta-...-5400-lens It started with a kiss, never thought it would come to this.
Post #820142 18th Mar 2020 9:10pm
ZeDefender
Apologies for the long text but this is what a friend (semi-pro volcano/penguin photographer) just replied to me:
The main 1st question is batch scanner or not. If its thousands and thousands of slides then you need a batch scanner that can scan the slides in their projector trays. Here you have reflecta batch scanners (OK quality but apparently tend to jam quite often; still available new) or the expensive high end Nikon coolscan models (trouble is they stopped being made in 2009 so risky getting second hand now).
For individual slide scans there are far more options but it is terribly laborious, but again coolscan models are OK. Problem is that slides tend not to be flat so need to manually focus slightly off center to get average OK sharpness. It all quite sh*t to be honest. If in glass frames, the frames tend to keep flatter but need to scan through the glass.
If lots of scratches / dirt then you need scanners with more error correction, yet this takes even longer.
Really dont know the current model line-up since last time i scanned was 10 years ago and I have resigned to not scanning (although actually maybe now is a good time as stuck at home - hmmm....)
This is a good read:
https://www.filmscanner.info/en/FilmscannerRangliste.html
Hope that helps !
p.s. and if you want to kill time looking at his photos, check out http://www.photovolcanica.com/
p.p.s. he's a miserable git but I still quite like him Rolling Eyes
Stay well!
Matt Tell someone you love them today because life is short.
Post #820151 18th Mar 2020 9:46pm
Minch90
If you can weld you are welcome to isolate in my garage and weld the chassis on my lightweight 😂 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime
S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down
S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround
Post #820165 18th Mar 2020 10:32pm
