Home > Maintenance & Modifications > WHich rear calipers to order?
donmacn
Well, I've had "one of those days". Following my fight with shock absorber bushes, I went to fit the new rear calipers and found...... they didn't fit either. Too fed up for words. Crying or Very sad
So I think I may have done this to myself, ordering 300Tdi calipers, and forgetting that the car has a more recent axle.
The existing casting - the one that came with the axle I suspect - is larger/wider here - the white line in the middle of the circle:
New caliper is narrower:
So, if I put the new caliper over the disc, the bolts won't line up with the threaded holes in the axle.
There's not much of a difference. I did measure but can't remember now - maybe 5mm or so - but enough that it won't fit. Same on both sides.
THe axle was a 'new take off' 2009 job - but as I've no VIN number I'm finding it hard to decide which parts to order. Can anyone help out? As always, I do appreciate it. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #819651 14th Mar 2020 9:14pm
donmacn
or.... after googling some more .... could I have the wrong disc?
Have the rear discs been the same for ever, or did they change? Specifically would the disc itself move inwards or outwards relative to the end of the axle?
I don't know if ABS will complicate things - my car doesn't have this, and I don't think the new axle did either. Donald
in the past..
Post #819673 14th Mar 2020 10:39pm
Retroanaconda
I think post-2002 ish the rear pads on 110s were made thicker to alleviate premature wear, which would mean wider calipers?
Post #819674 14th Mar 2020 10:39pm
donmacn
I didn't think to measure the width of the slot for the pads - didn't get past the point where I realised it just wasn't going to fit over the disc in the first place.
Its occurred to me that another option is for me to get a piston and seal kit and just refurb the calipers that fit - but the inner pistons are well and truly seized on both calipers. I don't have a compressor or 'air' to blast them out.
For the price of a caliper, it will be so much easier to buy new - if I knew which to get. Donald
in the past..
Post #819677 14th Mar 2020 11:02pm
donmacn
well that was interesting.
Existing caliper has a 53mm slot for the pads, the new one is 46mm.
So, lookimg very much as if I have ordered the earlier ones by mistake. A part number for the 2009 one would be ideal! Donald
in the past..
Post #819681 14th Mar 2020 11:28pm
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Post #819710 15th Mar 2020 10:04am
donmacn
^^^^ Thanks very much. I found my way to that page myself and it's looking like SMC500260 and 270 are the things I'm after.
I'll wait till Monday and speak to my parts shop. Donald
in the past..
Post #819718 15th Mar 2020 10:39am
epictrail
Worth comparing prices. I went AP last year when I changed mine but my mechanic says the Britpart ones are identical.
https://www.lrdirect.com/SMC500260-Calmper/?keep_https=yes
Post #819757 15th Mar 2020 4:39pm
