Home > Puma (Tdci) > Gearbox noise ????
GN
Gearbox noise ????
2011, 2000 mile 110 XS
When ever I come off the throttle slowing down at a junction there is a rattling noise coming from the gearbox area. It is the same if I have my foot on the clutch or not - its as though the clutch is not engaging or disengaging properly? The geras change fine once on the move, the problem only occurs when there is no load on the gearbox. I have switched between high & low - and back again - just the same. OK will have to go to the dealer - which I hate - I moved back to a defender due to all the issues I had with the D3 - Has anyone come across the same issue - any ideas ?????
Post #77523 24th Jun 2011 11:38am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Hand Brake is a good bet, try putting the hand brake on gently as you coast to stop and see if the noise disappears, been a spate of this recently maybe the recalls for leaking oil onto hand brake.
http://www.defender2.net/forum/topic7151.html?highlight= Original Member Pie n Pea Club.
110 HCPU Tipper
Post #77524 24th Jun 2011 11:41am
jlprojects
Wales 2011 Defender 130 Puma 2.4 HCPU Keswick Green
noise from gearbox when not under load
GN, sounds like the same problem I had, at about 60 mph it rattled and whined when I took my foot off. I drive back and to from poland to the UK so I didn't have much time to look at it in detail. I changed the transfer box and both props. Runs better than new now. John
Post #78343 29th Jun 2011 12:29pm
JSG
Hi GN, I have exactly the same problem - mine is a 2011 with 1500 miles on it and it has made the noise from new after a run. It doesn't happen all the time but seems to occur after driving for a while.
It doesn't matter if it is in gear or not, clutch is in or out or what gear it is in if in gear.
My handbrake seems to have travel (ie not biting early on the ratchet) and the dealer has checked it and said it is adjusted correctly.
Be interested to know what you find out from your dealer as it seems to be a common feature.
Cheers,
John John
2011 Tdci 110 CSW XS
Post #78361 29th Jun 2011 3:50pm
GN
Fixed - hand brake was the problem.
It was set very tight only one or may be two clicks.
I think it was binding a little - as you drove further so it got hot, when slowing down then it would catch.
Backed off to three clicks now - problem gone.
Thanks
Post #78387 29th Jun 2011 7:26pm
JSG
Hmm - maybe I'd better look at my handbrake again then Question John
Post #78397 29th Jun 2011 8:21pm
