Home > Puma (Tdci) > DGR Valve dead (or is it just sleeping?)
Page 2 of 2 <12
Naks
Kez wrote:
As I said, lots of people think this same, but as yet no one has pointed to and 'official' published research to substantiate that opinion. Surely if it was that simple fuel companies would add it at source for minimal cost and have a 'new' product that they could use for both a PR /marketing advantage as well as a premium product?
2SO makes diesel burn cleaner & adds lubricity, but increases nitrous emissions IIRC. there is a study floating around on the www about various diesel additives and their effects, will post it here if I find it. --
Post #77716 25th Jun 2011 10:14am
Kez
Isle Of Man
In that case will give it a go - any idea how much do I add to a full tank?
Post #77718 25th Jun 2011 10:18am
Naks
If it's the first time you're using 2SO, a 1:100 ratio, thereafter a 1:200 ratio. Use a good JASO-FB/C brand, but don't use full-synthetic. --
Post #77729 25th Jun 2011 11:00am
spudfan
Ireland
Just to confuse you even more use only use only JASO FC for the Puma. An example of this would be Castrol Activo. It appears that as the Puma has a catalytic converter the cheaper 2 stroke to the JASO FB specs would not be good for the catalytic converter. The amount you will be adding is actually very small so I would not be too concerned over any adverse effects. After you have used a few tankfulls let us know what you think. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #77732 25th Jun 2011 11:09am
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
I personally use 200mls/tank of Castrol Activo. Smile LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #77735 25th Jun 2011 11:22am
Kez
Isle Of Man
ahhhh, well by the time i read the above I had chucked in 0.5L of B&Q's finest, didn't blow up on the way home (so far have done 15 miles) and as yet no noticeable difference in anything other than my wallet. Early days I expect Smile
Post #77757 25th Jun 2011 2:04pm
spudfan
Ireland
Half that amount should be adequate. If you can add it when you fill up. Put it in before the diesel is pumped in, then it gets well and truly mixed. Looking forward to your observations after you have used a few tanks of fuel. 1982 88" 2.25 diesel
Post #77758 25th Jun 2011 2:20pm
Kez
Isle Of Man
2SOil update.
Well its now three tankfuls later, and I am pleased to report that the EGR valve has not played up once. At first it was intermittent in operation, occasionally not working at all after engine shut down, but after a hundred or so miles its become like clockwork (not often you associate that expression with a defender engine!).
While its only subjective, the engine feels smoother in particular on motorway speeds, so thats a bonus too.
As I mentioned the first tankful had a bit much added but there was no perceived negative effects, and since then I have just adde about 250ml to each tank and thats how I intend to carry on. So thanks to all for the advice Smile
Post #79321 7th Jul 2011 10:36am
Page 2 of 2 <12
