Home > Td5 > Engine cut out
Adammacky
Engine cut out
Currently sitting at side of the road waiting for AA man to come and save me.
Driving to work this morning and engine starts perfect first time, drove 5 miles and it starts juddering and losing power and engine light pops up, still drives for another half mile then cuts out completely, it starts back up and drives another mile before the same thing happens again and now wont start back up again.
Have recently (wednesday) had the solenoids changed in starter motor to brand new ones.
Sitting here freezing my t*ts off its -2! Banging Head
Any ideas???
Post #818429 6th Mar 2020 8:10am
Martin
Site Admin
Can you hear the fuel pump running when you turn the ignition on?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #818431 6th Mar 2020 8:35am
landy andy
Try with fuel cap removed in case of air lock.
How does pump and fuel sound during priming procedure?
Post #818437 6th Mar 2020 9:16am
Adammacky
This is the diagnosis from AA man, crankshaft sensor is faulty, thats the most likely thing he says, recovery truck on its way Banging Head
This has been one of the worst days...
Post #818448 6th Mar 2020 9:52am
dorsetsmith
check wiring and plug to the sensor also
Post #818465 6th Mar 2020 11:27am
othorton
United Kingdom 2005 Defender 90 Td5 CSW Java Black
I'd say you've dodged a bullet to be honest.
I had a similar issue which turned out to be the ECU. New CPS = £35, ECU rebuilt = £350
We changed my CPS as a precautionary measure as we thought it might be the issue and it was covered in both oil and fuel from a leaky FPR. CPS is relatively easy to change, though a bit of a Censored to locate: Looking at the bellhousing from the offside wing nearest the windscreen it's at about 11pm.
Post #819069 10th Mar 2020 9:44pm
MadTom
Just for info - to test run TD5 engine, you can use any TD5 engine ECU, you just need to pair it with imobilizer (10AS) in car, and probably set the right type of fuel pedal, to be able to increase engine RPM. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #819096 11th Mar 2020 9:03am
