![]() | Home > Td5 > Defender td5 vibrate |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8369 ![]() ![]() ![]() |
engine mounts? exhaust knocking, damper shot
first things i would look at. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
Misfire? Or DMF out of bonk?
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6205 ![]() ![]() ![]() |
Mine gets a misfire every now and then.... pop the rocker cover off, squeeze the crimps up a little on each injector plug and it goes away.
You get a bit more smoke when it's misfiring too, so something to look out for. DMF would be my next port of call as mentioned above.... I changed mine last year and it made a lot of difference to the smoothness... so much so that SWMBO even noticed! ![]() |
