Home > For Sale & Wanted > [Wanted] TOP "A" frame fitting brackets (edited)
Stacey007
Hello
Does anyone have the brackets by any chance or know where I can source...or what they look like?
I have these but think these are from the top?
Thanks
Post #816988 25th Feb 2020 11:57pm
landy andy
They are the bottom brackets.
Post #817009 26th Feb 2020 8:58am
hank
They're the bottom ones but the way they are photographed they are 90 degrees out of rotation.
The flat piece with two bolt slots goes under the bumper/bumper bolts and the narrower bit with one bolt slot goes alongside the chassis rail and gets bolted by the tie ring eye bolt > 110 XS Double Cab
Post #817015 26th Feb 2020 10:05am
Stacey007
Hello
Thanks people
Does anyone have the top brackets or are these what I need> look like they could be
Thanks
Post #817017 26th Feb 2020 10:13am
ARC99
They are the top brackets, just be careful you get them handed as per the originals supplied by Land Rover. I bought a set of replacements , don't if it was from that company, they were not handed and did not fit as a result. Just had a second look at the photo, they are not the ones I bought, it may be worth giving them a call to check. Don't make old people mad.
Richard
Post #817023 26th Feb 2020 10:36am
Stacey007
Hello
Do you mean there is a left hand and right hand bracket Smile
If so it seems to suggest they are sold in pairs so will check
Thanks
Post #817025 26th Feb 2020 10:39am
ARC99
Yes, a left and right hand side same as the lower ones. If you look at the second photo, that's on the off side ,on the Flatdog site you can see how they fit, the near side is a mirror image. Don't make old people mad.
Richard
Post #817026 26th Feb 2020 10:43am
hank
For info, my upper brackets are not 'handed' they are both identical > 110 XS Double Cab
Post #817048 26th Feb 2020 2:43pm
Stacey007
Ben from FatDog parts got back to me..
He agreed they are not handed?
"The top defender ABAR brackets are not left and right handed – they are a universal bracket- same as LR part"
Post #817058 26th Feb 2020 4:45pm
hank
I've previously read on the forum about people having handed brackets! Mine weren't that's all.
You can see from the below pics the top brackets with both of the extended 'tang' on the right hand side
 > 110 XS Double Cab
Post #817065 26th Feb 2020 5:25pm
ARC99
I'm only going to add, the one I purchased from a Forum member had Land Rover sticker on the under side which had LHS and RHS on them. Don't make old people mad.
Richard
Post #817338 28th Feb 2020 10:16am
hank
I can believe it. Wish mine had been! > 110 XS Double Cab
Post #817359 28th Feb 2020 11:24am
