Home > Technical > Wanted: Safari Snorkel Installation Guide for a TD5.
3 Lions
Australia 2006 Defender 110 Td5 SW Chawton White
Hi, would anybody have an installation guidefor a Safari snorkel for a Td5 Defender.
I ordered one from Paddocks, and had it sent over to Aus.
The one sent was for a TD4 Puma engined Defender, when I got hold of Paddocks and told them they had sent the wrong one they said the part number was now for the TD4 and TD5 Defender.
Safari snorkels comfirmed this and also there website says the same thing.
The problem is that the installation guide is clearly based around a TD4 Puma.
So if anyone has an old one they could scan that would be much appreciated.
Bow down
Cheers, Col. Thumbs Up
Post #77110 22nd Jun 2011 11:13am
MK
Try the safari snorkels web site (it was there) Thumbs Up Puma 110" SW
Post #77138 22nd Jun 2011 3:37pm
JSG
I wouldn't have thought the instructions would be that different as the fittings to the wing and screen are the same on both models. As it is classed as a RAI the inner ducting doesn't get touched does it? John
2011 Tdci 110 CSW XS
Post #77144 22nd Jun 2011 4:53pm
3 Lions
Thats the one for the TD4 Puma.
Post #77217 22nd Jun 2011 10:25pm
3 Lions
The outside is the same, but it is the inner ducting and airbox etc which are different.
Col.
Post #77218 22nd Jun 2011 10:26pm
MK
Have a look http://www.safarisnorkel.com/snorkel/ss1130hf/ss1130hf_guide.htm Puma 110" SW
Post #77228 23rd Jun 2011 2:47am
3 Lions
Thanks, but thats the one I already have which is for a TD4 Puma....
I have a TD5.
Col.
Post #77229 23rd Jun 2011 3:44am
JSG
Col.
Apologies if I'm missing something but the inner ducting isn't part of the RAI fitting is it? John
Post #77240 23rd Jun 2011 8:46am
Happyoldgit
I have a TD5.
Col.
But you need only be concerned with the exterior fitting and mounting of the thing which is the same as the Puma. Sealing of the inner pipework etc is down to you anyway. Steve.
http://forums.lr4x4.com
Post #77242 23rd Jun 2011 9:28am
3 Lions
Miserableolgit wrote:
I have a TD5.
Col.
Your dead right, but because the instructions are showing various photos of bits to seal on the inside (on the TD4) I'm thinking, well that would probably be a good idea to do on my TD5.
My D2 is a V8 Petrol, which I fiited the snorkel onto.I considered it not quite as vital in 100% completely sealing it when I fitted it, but the TD5 being a diesel......
Well. lets just say maybe I'm a bit paranoid about water getting into the engine, but Land Rover parts over this side of the world are not cheap. Sad
Post #77254 23rd Jun 2011 11:02am
Happyoldgit
Take an objective look at the internal ducting and drains and then get to work with the sealant Wink Steve.
Post #77255 23rd Jun 2011 11:16am
WarPig
Dont know if this is any use to you, but heres some photos of my 300tdi safari snorkle instructions, and how I fitted it..
Post #77413 23rd Jun 2011 7:44pm
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
SS 575HF
Installation Guide
Click Image above for High Resolution Diagram
LANDROVER DEFENDER 110 TD5 TDI 2.5L JANUARY 1999 ONWARDS 5 CYLINDER
Fitment to: Right hand side Fitting time: Approximately 75 minutes Special Tools:� Unibit Step Drill � 25mm Holesaw
1 Remove: � Air intake grill from the right hand guard. � Radio antenna from the right hand guard. � From inside the engine bay, remove the genuine plastic air intake duct.
2 Cut the lower antenna mount off flush with the panel work to allow clearance for the air entry hose. File cut edge smooth and paint to prevent rust.
3 Tape the template in position on the upper rear corner of the guard and mark the mounting hole locations using a felt pen. Remove the template. Drill the mounting holes to 16mm using a step drill. Deburr holes and paint.
4 Bolt the upper mounting bracket into position on the snorkel body. Insert the stainless steel studs into the back of the snorkel. Locate the snorkel on the vehicle and mark the upper mounting hole locations on the windscreen frame using a felt pen. Remove the snorkel from the vehicle.
5 Drill the mounting holes to 3.5mm. Using a small amount of silicone, stick the foam gasket to the back of the snorkel body. Use the same method to join the upper mounting bracket to the bracket gasket.
6 Install steel joiner (Item 13) into standard flexible duct and fasten using genuine hose clamp. Lubricate both ends of this air entry hose (item 12) with CRC or a similar lubricant and install the air entry hose and hose clamp (Item 15) onto the snorkel snout loosely. Position the snorkel body onto the vehicle and fasten using appropriate hardware supplied in the kit.
7 Connect the air entry hose to the steel joiner and fasten using hose clamp (item 14). Ensure that the air entry hose and genuine flexible duct have adequate clearance to all panel work, brake lines and steering column universal joint.
8 Radio antenna (if fitted to right hand guard) must be relocated 60mm forward. 1/ Measure 60mm forward from the front of the existing antenna hole (refer to drawing), using a felt pen mark the new antenna hole position.2/ Drill a pilot hole, then use masking tape to mask an area of approximately 100mm sq to protect the paintwork whilst drilling with the holesaw.
9 Refit the radio antenna to the new position. Blank - off old antenna hole using blanking grommet (item 16) fit the air ram to the top of the snorkel and tighten clamp.
WARNING: IT IS THE INSTALLERS RESPONSIBILITY TO ENSURE ALL CONNECTIONS ARE WATER TIGHT.
ITEM IMAGE DESCRIPTION QTY PART NO.
1 BODY - SNORKEL 1 810-133-400
2 3 �" AIR RAM ASSEMBLY 1 000-135-650
3 BRACKET - Upper Mounting 1 810-032-200
4 GASKET-Upper Mounting Bracket 1 810-435-200
5 BOLT -Hex - 6mm X 1.0 x14mm 3 000-002-100
6 STUD - 8mm X 1.25 X 25mm O/L 3 000-110
7 WASHER BODY 3 000-311
8 NUT - NYLOC -8mm X 30mm 3 000-205
9 SCREW - S/T - 4.2mm X 13mm 4 000-951
10 GASKET - FOAM BODY 1 810-016-200
11 TEMPLATE 1 810-017-200
12 HOSE - AIR ENTRY 1 810-024-200
13 JOINER - 63 X 65mm 1 610-025-000
14 CLAMP - HOSE 60/80mm 1 000-907
15
hope this helps
john 2004 TD5 Defender 90 xs station wagon
Post #77742 25th Jun 2011 12:18pm
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
anyone got a template
Post #114746 12th Jan 2012 9:13pm
alanhid
Scotland 2006 Defender 90 Td5 XS CSW Bonatti Grey
Me Whistle Do you need one? Life is not a rehearsal!
Def 90td5 CSW xs 2006
Post #115035 13th Jan 2012 6:02pm
