Home > V8 > 3.9 v8 auto reversing lights
Fufflenarnia
United Kingdom 1991 Defender 90 V8 Petrol HT Auto Baltic Blue
Hi all,
I have recently bought a 92 defender with a 3.9 v8 auto conversion, I believe it’s from a discovery 1 or rrc.
Anyhow, the wiring is scary in the car (lots of joins and dead wires) so I’m going through tidying it up and fixing things as I go.
The reverse lights are on my list - where is the connection point For the rear light cable on the v8 loom please? I can see the inhibitor switch and the cable go up to a plug with 6 wires, 2 coming back and isolated (black, red), 4 from the switch and the loom going up. Does the cable go directly to the ecu? (My ecu is mounted under the cubby between the seats, so the cable goes through the bulkheadj. I assume the reverse light cables plug into the loom somewhere between the ecu and the plug to the reverse light/inhibitor switch, but I can’t see where.
Thanks,
Post #816504 23rd Feb 2020 9:01am
If there’s a green/brown coming out of the gearbox, they should be to the reverse lights, green is a live feed from your reverse fuse.
It’s been 4 years since i did mine and can’t recall without going through a load of paper notes, but thats what i remember. QRZ M8VPF
Post #816609 23rd Feb 2020 7:31pm
Fufflenarnia
Thanks,
Found the switch on the gearbox, removed it, cleaned it and bing, all good and working:-)
Post #831533 17th May 2020 11:07am
Fufflenarnia
Someone had used a 7 way trailer wire half way along the wiring, so lots of belling out required, but all sorted, I'd even wired in the rear wiper, washer (added a washer bag in the back) and heated window.
Post #831536 17th May 2020 11:10am
