![]() | Home > Puma (Tdci) > Under bonnet seals |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
Can’t remember the part number but I bought it from the dealer. Unless you insist on avoiding the dealer at all cost they won’t cost you a lot.
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 306 ![]() ![]() ![]() |
Due you mean the short seal on the wing next to the bulkhead?
If so it’s P/N LR038612 |
natyeo Member Since: 27 Jan 2013 Location: Bentham Posts: 138 ![]() ![]() ![]() |
Thank you 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
2012 2.2 tdci 110 Utility 1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going 1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms 1971 Series 3 88, Perkins 4203,M8000,SATs,O/D, |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 588 ![]() ![]() ![]() |
Funny, I bought my MY2009 90 2.4 new, and there is no such seal on mine (maybe because it's LHD? None of the LHD ones I've seen have that either)
I've ordered one for each side, always thought something was missing there! ![]() -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1124 ![]() ![]() ![]() |
My LHD has them. One was about to fall off however, so I put some dumdum inside so they stick to the wing.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17916 ![]() ![]() ![]() |
My 2007 Puma has never had them. Do they do anything useful?
Jerry Member Since: 13 Nov 2015 Location: Cardiff Posts: 210 ![]() ![]() |
they stop (...or at least reduce) water cascading down from the wing tops onto the bulkhead in engine bay in torrential weather.
I added a second one and stopped the ingress via the blower gap https://www.defender2.net/forum/topic47380-15.html |
yep. I've also put some dumdum underneath the gap between wing and bulkhead.
Hmm, I've never found the former to be a problem, and I have a properly fitting heater duct, so I guess the answer to my question is "no"! They seem to be rather expensive for what they are. I guess if I managed the last 12 years without knowing that I needed a pair, I probably don't! |
![]() did you watch the video from minute 12:00 to 13:00? 'orrible ![]() |
No, since personally I find that fellow completely insufferable (not intended as a criticism, please note).
