Home > Td5 > Another non starter
Adammacky
Another non starter
Morning everyone...
...appreciate there are lots of similar threads on here already but as title suggests, my 1999 td5 wont start at all.
Upon turning the key i get one very quiet click, radio comes on fine as well as heaters and also immobiliser working fine.
After reading many a thread in here i am thinking it must be the starter motor?
Had to hitch a lift to work and wont be able to look at it till tonight so any advice in advance would be great.
Never had problems with ignition before.
Thanks!
Post #815755 18th Feb 2020 10:12am
dorsetsmith
Is engine cranking over Question with starter motor
start by checking the battery terminal and neg down to chassis and to transfer box
next fuse see below
next relays i.e. starter - fuel pump - main relay
MY 1999 to 2001 relay
driver seat box ( MY1999 rave )
working from foot well end
first yellow relay cooling fan
next one yellow relay compresses clutch A/C
next one black relay Glow plugs
next one black relay ABS return pump
next one yellow relay ( main )
canter box fuse box ( MY1999 rave )
working from passenger side
first yellow relay starter
next yellow relay heated rear screen
next yellow relay head lamp
next brown relay sounder alarm
next green relay fuel pump
also ecu delay windscreen wiper unit brown / relay hazed warning black
Post #815761 18th Feb 2020 10:57am
Adammacky
No cranking over at all, will check the above when i get home, thanks for responding Thumbs Up
Post #815762 18th Feb 2020 11:07am
landy andy
The solenoid on the starter has failed. Very common problem. Either new starter or fit parts to solenoid. You could also take starter off and take to have rebuilt if it’s a quality make. Repetitively flicking through key may get it to start occasionally, or a tow.
Also check you FPR (fuel pressure return) valve, which is on side of cylinder head above starter and can drip diesel on to starter that then causes the solenoid to fail.
Andy.
Post #815764 18th Feb 2020 11:17am
Adammacky
Back home now and been doing some routing around and couldnt find any obvious problems, have flickered the key a bit and managed to get it started, turned off ignition and tried again and started first time perfectly, so I'm guessing it is the starter solenoid as landyandy mentioned?
Thanks for the help guys Thumbs Up
Post #815825 18th Feb 2020 6:02pm
dorsetsmith
Post #815849 18th Feb 2020 7:36pm
Adammacky
Watched this video earlier, looks simple enough, how hard is it to remove from a defender though, access doesnt look good from what i can see, anyone done theirs recently and got any tips?
Post #815864 18th Feb 2020 8:08pm
Adammacky
Ignore the above ive found the thread on here about removal and all the answers are in there! Time to order the replacement parts then!
Post #815869 18th Feb 2020 8:25pm
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
One fixing is a PITA, just take your time. Remember to disconnect the battery first?
Post #815878 18th Feb 2020 9:07pm
landy andy
The starter is ok to remove but there is one hidden nut, and it’s an odd size. Can’t remember what size though, been a while since I’ve done it. Don’t go cheap with the replacement Thumbs Up Thumbs Up
Post #815898 18th Feb 2020 10:41pm
Dieseljock
Scotland 2003 Defender 90 Td5 HT Zambezi Silver
The repair kit can be fitted to the starter whilst it’s still in place I’ve done it loads of times. As above make sure you disconnect the battery.Remove front cover 3bolts 8mm socket. Pull out plunger and spring, undo 2 m8 nuts for contacts and remove contacts.Fit new contacts,Leave both new contacts loose and push the plunger in to set the contacts level, then nip up the contacts. If their not set level they’ll burn out quicker. Fit spring and plunger refit front cover. Can be done in less than half an hour
Post #815901 18th Feb 2020 11:05pm
dorsetsmith
15mm if can use 6 point socket
Post #815902 18th Feb 2020 11:08pm
Adammacky
Repair kit ordered and plan to do this Saturday morning while theres day light, will update accordingly
Post #815906 18th Feb 2020 11:21pm
Adammacky
Would of loved to come on here and say job done... however thats not the case Banging Head
2 bolts i got off from underneath no problem at all, the nut at the top though a real PITA! How on earth can you get good access to it?!
I removed the hose in the way to get a better look but could barely even get the socket but to fit on it let alone the socket extension!
Then it started to p**s down with rain! So i gave up!
Mechanically I am a novice too, probably doesnt help!
Post #816439 22nd Feb 2020 6:52pm
miker
From memory I've done it from above with an 18" extension in the past. When It's light tomorrow I'll have a look and refresh my memory!
Post #816448 22nd Feb 2020 7:36pm
