Home > Maintenance & Modifications > Ifor fitting question.
All Terrain
United Kingdom 2004 Defender 110 Td5 XS DCPU Java Black
Should the holes for the hood sticks be ground flush with the top of the pick up tub in order for the canopy to fully contact the tub?
Just wondered.
Whistle
Post #76862 20th Jun 2011 6:58pm
NoDo$h
Mine sits nicely on top of the hood stick holes. The lip is deep enough to still sit over the cappings and the seal (ish) against the cab back is lined up about right (ish) at that height.
By "ish" I mean "with LR Manufacturing Tolerance" or "you can drive a bus through it". Thumbs Up
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #76863 20th Jun 2011 7:08pm
All Terrain
Ah ok well that is what mine does and seems stable with the same tolerances that you mention. The onlt reason I asked is that the Ifor tailgate and the LR tailgate have about a 10mm gap between them which appears to be about the same as the tops of the stick holes. If they were ground down then they would meet (almost).
Supposed that would throw out the precsion fit of the rest of the canopy! Laughing
DJ
Post #76865 20th Jun 2011 7:26pm
All Terrain
My typing is about as precise as the canopy fit! Embarassed
Post #76866 20th Jun 2011 7:27pm
No, leave the hood stick sockets as they are, it is designed to sit on them. The gap under the flap is normal. It is possible to get a rubber trim strip seal thingy that will cover the gap and still allow either tailgate to open first, I was going to do this but decided in the end not to bother.
Post #76874 20th Jun 2011 8:32pm
All Terrain
Blackwolf,
Good advice thanks, just had a closer look tonight and spotted the rubber stops that the canopy sits on and allow it to clear the stick holes.
Must say I just chucked it on when I picked it up today.
Must say it has transformed the look of the vehicle.
Cheers,
DJ
Post #76907 20th Jun 2011 11:25pm
MuddyMarky
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
AT, would you mind posting up a pic of your DC with the top fitted please? Trying to decide to get a DC and the IW top is an option, but can't really find any decent pics of one fitted.
Thumbs Up Mark
2011 110 XS DC
Stornoway Grey
Post #77885 26th Jun 2011 10:44am
All Terrain
MM, will take some tomorrow and post them up for you.
Cheers,
AT.
Post #78812 3rd Jul 2011 5:23pm
All Terrain
MM can you PM me your email address and then I'll email you the images as posting here is a bit long winded.
Cheers,
David.
Post #78916 4th Jul 2011 10:06am
MuddyMarky
The DC is now top of my list (even seen one I'm going to buy should my D3 suddenly find itself sold), so would be good to see the piccies.
Just PM'd you Thumbs Up Mark
2011 110 XS DC
Stornoway Grey
Post #78977 4th Jul 2011 5:49pm
