Home > Off Topic > 25 litre plastic drums.....
Does anyone happen to know how much internal (As in, air/fluid) pressure a normal 25 litre oil drum, plastic type with screw on cap, can handle before it goes pop?
I'm trying to use one to fill & pressurise my roof solar panel water heating system. Needs to go to 2bar, but (using my garage compressor to charge it), the drum expands quite a bit. and I don't fancy having glycol all over the attic and ceiling below.
Tried googling but just seem to end up with home brew 25 litre kegs.... but still no mention of the pressure limit.
Might have to try using a steel jerrycan instead.
Post #814105 7th Feb 2020 9:46pm
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
It sounds highly risky to me especially in a loft space. 2016 Defender Landmark 90
2005 Defender CSW TD5 90XS
Post #814108 7th Feb 2020 10:53pm
The only way to find out is to hydraulic test one - fill it with water to the brim the pressurise it from your compressor until either you get to about 4 bar or it bursts. If it's ok at 4 bar you are *probably* ok at 2.
Filling it to the brim with water means it won't explode if it bursts since water is incompressible, this is the same way we hydraulic test loco boilers.
Post #814124 8th Feb 2020 12:32am
SteveRat
United Kingdom 1995 Defender 90 300 Tdi CSW Arles Blue
When I did mine I used a plastic spray container (used for weedkiller etc) from B&Q I think. They are designed to be pressurised in order to vaporise the spray. Not sure what it held but it stood about 18" high perhaps 8"-10" diameter.
Post #814127 8th Feb 2020 1:59am
HK07
England 2007 Defender 90 Puma 2.4 HT Cairns Blue
What about using an old calor style gas bottle?
We sell them at my work, and we have some empty big old ones that are surplus, you're very welcome to one of them.
They're just outside Hindhead. 2007 90 Puma - Love it - Best car I have ever owned.
1989 Ninety 200tdi - Love it - Second best car I have ever owned.
1951 80" Series 1 - Love it - Third best car I have ever owned.
Post #814154 8th Feb 2020 10:07am
