Home > Td5 > Springy question - answers most welcome. |
I think you're right about the handing but the longer springs should go on the back. This is based on the fact that rear OE springs have more coils and longer free length than front ones.
To give you an idea of what I mean, take a look here: http://www.red90.ca/rovers/springinfo.html That table doesn't cover some of the later spring spec's/colour combinations but it does illustrate the general point about rear springs being longer. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
6th Feb 2020 11:12pm |
You can download a spring calculator on your phone to calculate the spring rates. With this you know which ones belong together and normally the higher spring rates are for the rear. The longer springs for the drivers side.
If you measure accurately the numbers will come close to the given values. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
7th Feb 2020 6:40pm |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 |
After phoning Flatdog and speaking to their tech chap who couldn’t have been more helpful I think roel was spot on.
The long springs both belong on the driver side with the 7 3/4 turn ones on the front and the 8 1/4 turn ones on the rear. I can now get it booked in and change my 16 year old springs and shockers to hopefully get a nicer ride and lose it’s permanent list to port. Hopefully this info will help if anyone has a similar quandary. |
13th Feb 2020 9:36pm |
