Home > Wheels & Tyres > Tyre pressures on 7.50 x 16
Landy nut
United Kingdom 2006 Defender 90 Td5 PU Epsom Green
Evening all. Just an odd question really as I have not run this size tyre before. My 90 pickup has a set of 7.50 x 16 Michelin Latitude Cross tyres on and I want to know what pressure to run them at for a comfortable ride. Had them filled at ATS when I had the tyres fitted but I wonder if they are too hard. Not sure on current pressure but will be checking sometime over next couple of days.
Thanks
Post #76735 19th Jun 2011 9:06pm
NinetyTD4
Wales 2012 Defender 90 Other SW Keswick Green
Simply make the chalk test and vary for your convenience within the good range. Never forget: cars have owner, Landrover have field service personnel.
Post #76740 19th Jun 2011 9:15pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
try this
Tire sizes
Model Tire size
90 205/80 R16 Radial
265/75 R16 Radial (Multi terrain)
7.50 R16 Radial
110 - except Japan 7.50 R16 Radial
110 Japan 7.50 R16C
130 7.50 R16 radial
Tire pressures
Model - Tire size Front Rear
90 - 205/80 R16 1,9 bar 2,6 bar
28 lbf/in! 38 lbf/in!
2,0 kgf/cm! 2,7 kgf/cm!
90 - 265/75 R16 1,9 bar 2,4 bar
28 lbf/in! 35 lbf/in!
90 - 7.50 R16 1,9 bar 2,6 bar
110 - 7.50 R16 (except Japan) 1,9 bar 3,3 bar
28 lbf/in! 48 lbf/in!
2,0 kgf/cm! 3,4 kgf/cm!
110 - 7.50 R16C (Japan) 2,2 bar 4,1 bar
32 lbf/in! 60 lbf/in!
2,3 kgf/cm! 4,3 kgf/cm!
130 - 7.50 R16 3,0 bar 4,5 bar
44 lbf/in! 65 lbf/in!
3,1 kgf/cm! 4,6 kgf/cm! BM52
Post #76745 19th Jun 2011 9:43pm
Landy nut
Ta awfully!
Post #76878 20th Jun 2011 8:04pm
