Home > For Sale & Wanted > SOLD Aluminium Roof-Rack to fit Double-Cab Defender
66north
Used Aluminium 'Expedition' Rack to fit 110/130 double-cab. Supplied with mounting brackets and fixings.
Sorry, don't know the brand. Came with the truck. Usual slotted extrusions for dropping M8 bolts into for fastening whatever you want to the rack.
Rack is in good condition. It's had one small (8mm) hole drilled into the deck but other than that, platform is perfect.
One end of the rack has a Labcraft 1400 lumen Scenelite attached to it.
Bad stuff. The powder coat is peeling off all of the six steel mounting legs leaving some rusty areas. A good clean and repaint/powdercoat would easily sort these out.
If you're thinking of using it on a 90 or 110, the overall length of the rack is 160cm. FWIW. When mounted on a 90 the front of the rack would end up half-way down the sloping section of the roof.
£300.
Located: W Yorks. Collection only but happy to assist in mounting to driveaway!
Post #811776 24th Jan 2020 3:40pm
JSaxton
Pm sent
Post #811793 24th Jan 2020 7:21pm
