Home > Maintenance & Modifications > Door mounted spare - Bad Idea? |
Rye54 Member Since: 09 Jul 2017 Location: Scotland Posts: 48 |
Afternoon,
Last weekend I spent a bit of time adjusting the strike plate, tightening the hinges etc. on the rear door of my 90 puma to reduce the amount of rattling coming from it, especially when going over bumpy ground. Whilst I was there I removed the door card off the rear door to see if there were any stress fractures but the door looks to be in great condition, even after 13 years carrying a boost alloy on it. I plan on replacing my boost alloys with wolf wheels in the near future and had planned on fitting a spare wheel carrier to take the extra weight (~3kg difference) but now I'm questioning whether I really need to? I know there are a lot of advocates for spare wheel carriers which surely says something, but does anyone have any experience of mounting a wolf wheel directly onto the door and if so how did the door fare in the long run? Click image to enlarge |
23rd Jan 2020 2:00pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2520 |
Rye
Something worth doing is to get some Silent Coat from the Sound Deading Shop, direct or EBay. Cut it to fit the panel where it sounds tinny, you don’t need to cover the entire door. Then add some to the inside of the door panel. It will make a difference even for not too much money. Good luck |
23rd Jan 2020 6:33pm |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 389 |
Several things influence this including
Size/weight of spare Whether you travel on rough roads a lot How you and the passengers treat the door The last one is surprisingly significant. If you treat it like a squaddie and hurl the door shut with maximum force from fully open "because you always need to slam Land Rover doors" it will eventually break even with a 7.50 on it. If you close it firmly but gently then no problems. I've not had a problem with my 13 year old Tdi nor the 5 year old Puma but I treat it sensibly. --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
25th Jan 2020 4:29pm |
