Home > Maintenance & Modifications > Rear axle with drums, what happens to the oil? |
htb2 Member Since: 02 Nov 2018 Location: aberdeenshire Posts: 507 |
Early axles like yours are lubricated by the diff oil, only later ones had the oil seal on the halfshaft (300tdi and onwards IIRC).
When you go back on the level it will go back to the diff. Unless your hub seals are knackered and it ends up running down the inside of your disc |
21st Jan 2020 12:51pm |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 |
In axles of that vintage the wheel bearings are lubricated by oil rather than grease. A far better system which had served Land Rover well since 1948.
The hub seal should retain the oil, earlier seals were of a different design to the post 1993 300tdi seals. In fact removing the stub axle seals is a better idea than retaining them It is not a Defender, it is a One_Ten |
21st Jan 2020 1:39pm |
