![]() | Home > Technical > Td5 oil in red ecu plug but not at the injector harness end. |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
Oil travel down inside cable with copper wire
clean out the red plug and keep an eye on it (brake cleaner) good at cleaning oil out going to be long job |
| Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845
For a number of reasons I purchased the extendable loom, it now sits above my head in the truck, well away from water and no oil will trav l that far up a loom
Just a thought like, I did this after it’s first injector loom change |
| roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039
I positioned my ECU between the seats against the bulkhead in my 90. The connectors from the ecu are pointing down. I think that helps too. Roel
| LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 886
Interesting, thanks for the replies, i’ll clean it out initially but it is tempting to relocate it with cables facing down.
Where did you bring the loom up through? |
https://www.google.com/imgres?imgurl=https...amp;uact=8
Test if this works. Not mine but did more or less the same Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
I only needed to extend one off the Tranfer box sensor cables. Not sure if it was high-low or difflock. Roel
The extender loom is long enough to locate it up on my “dog guard” right up the top by the headlining, was about £200 in its day though, but touch wood never given me any issues since fitting |
Thanks for the replies. Looks like this could be a job for the future. My slimline subwoofer is currently mounted on the bulkhead but there might be room to squeeze the ecu in there somewhere. Initially i’ll give it a good clean and see how it goes for the time being.
| All times are GMT |
