Home > Maintenance & Modifications > Exhaust newbie - do I need to use paste?
donmacn
Morning all,
Despite working on cars for a few years, I've never actually done any work on exhausts. I think mainly because it's a job that's much easier with a ramp, and I've never had access to one of them - so I've usually left this to garages.
Now though, as part of the rebuild/refurb I have a quality stainless exhaust to fit, and find I'm lacking some basic experience.
The mounts and clamps will be easy enough ( good quality T- bolt clamps etc ) but when I'm assembling it - a stainless exhaust - do I need to use any kind of paste or sealant on the pipe joins?
Thanks in advance
(300Tdi 110 if it makes any difference) Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #810838 18th Jan 2020 12:12pm
htb2
Wales
Didn't, with my stainless system on my 300tdi 90, No problems since or at MOT time
Post #810839 18th Jan 2020 12:26pm
landy andy
No. Not needed
Post #810840 18th Jan 2020 12:26pm
donmacn
Thanks very much gents. It certainly makes life easier.
I knew exhaust paste existed, so kind of thought it might be for routine use. Donald
in the past..
Post #810852 18th Jan 2020 3:57pm
htb2
Wales
Bodgers paste for filling gaps in misaligned sections.
Post #810864 18th Jan 2020 5:20pm
Flanged mating surfaces on the Defender systems so not used. (Unless aftermarket.)I didn’t either.
The only place sealant paste would be used that I could think of is two scenarios.
1.) Misalignment causing exhaust gas leaks, temporary solution. Should be fixed properly.
2.) Sleeve fittings with clamps, mainly due to again misalignment.
I wouldn’t use it really unless you find it’s required, more of a fix than a requirement. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #810880 18th Jan 2020 6:32pm
Litch
As above, paste should not be required.
As a matter of interest what make of exhaust have you bought, if it is a DoubleS then check it before fitting? Confused
I bought one for my 300TDi 90 several years ago and it went straight back due to the poor quality of manufacture. Not only was the CSA of the pipe considerably smaller than the genuine system it was replacing but the downpipe was flattened at the 90degree bend. When I queried it with DoubleS they said it wasn't a problem and they had sold lots like it! Needless to say it went straight back and the SS system I replaced it with was properly built and fitted & worked perfectly.
Took delivery yesterday of a Demand SS system...…………………… lovely! Very Happy
DoubleS downpipe.
Demand system (stock photo).
 ONE LIFE, GET IT!
Post #810889 18th Jan 2020 7:46pm
donmacn
I think I'd seen this thread/post about these exhausts before, and registered enough to know that it wasn't an option I would go for. I've got a Griffin system for mine - appropriate for all the other engine mods/enhancements which I've found myself doing/having done.
Won't say any more at the moment - not trying to be a t*ss*r, tease or any such thing, just that I'm kind of looking forward to the big 'reveal' in my rebuild thread below. Confused Donald
in the past..
Post #810917 18th Jan 2020 11:29pm
donmacn
The only place sealant paste would be used that I could think of is two scenarios. .
Steve - thanks - hadn't seen your reply earlier on the phone.
As above, hopefully the quality of the Griffin system will avoid any such issues.
But... a more general question after all of the above feedback. If there were small leaks in the system, how would I know? I know what a blown exhaust sounds like - even a 1.2 Clio can sound like a Harley - but if it was 95% OK, just leaking slightly, would I be listening for soemthing, or looking for soot traces, or what...? As I say, I've just never done this particular job before. Donald
in the past..
Post #810923 18th Jan 2020 11:59pm
