Home > Off Topic > Recall - Range Rover, Range Rover Sport |
Alert number: A12/00019/20
Category: Motor vehicles Product: Passenger car Brand: Land Rover Name: Range Rover, Range Rover Sport Type / number of model: Type-approval numbers: E11*2007/46*0649, E11*2007/46*0909 Batch number / Barcode: N306 Risk type: Injuries The routing of the electrical harness within the steering column assembly has insufficient clearance to the metalwork of the steering column, causing the harness to be damaged or pulled out of the connector when the steering column is adjusted. This can result in impaired steering functionality and failure of the horn and the direction indicators, increasing the risk of an accident. Measures taken by economic operators: Recall of the product from end users (By: Manufacturer) Description: Passenger car under Land Rover recall code: N306. Country of origin: United Kingdom Alert submitted by: United Kingdom Type of alert: Serious Products were found and measures were taken also in: Ireland https://ec.europa.eu/consumers/consumers_s...amp;lng=en |
17th Jan 2020 10:15am |
