![]() | Home > Puma (Tdci) > Someone Must Have An Answer! Manifold To Turbo Seal. 2.2TDCi |
| Crash7 Member Since: 21 Feb 2024 Location: South Posts: 43
Thread revival! - Did you ever fix this? If so how?
| roddyfox Member Since: 14 Mar 2017 Location: Kenton-on-Sea Posts: 10
Yes, but I took the vehicle to a Land Rover specialist in the end - I can't quite recall what he did but can ask him tomorrow.
(A lot has happened since then - the Covid era and a new engine!)
| JPE Member Since: 19 Nov 2018 Location: South West England Posts: 347
I had a similar issue with an exhaust smell in the cab. I took it to the garage for a smoke test & they found a leak between exhaust manifold & turbo. They told me that the problem was that the gasket between manifold & turbo was missing and so they fitted one.
Now I'm googling I can only see a gasket for the 2.4 and not the 2.2 & I'm wondering if it should ever have had a gasket? Anyway this was a few years ago and it seemed to fix it. |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18038
The 2.2 WSM indicates that there is no gasket between the turbo and exhaust manifold on the 2.2.
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2511
Yes, the 2.4 needs/comes with a gasket between the exhaust manifold and the turbo. Ford p/n 1505921 Click image to enlarge Puma 110" SW ............................................................. Earth first. Other planets later |
