Home > Tdi > Exhaust fitting -any tips
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
Just about to fit middle pipe and box also back box. It was difficult enough getting the old bits away from the hangers so I am wondering if there is an easy way when fitting the new bits to the hangers as the hanger holes seem too small to take the shrouds on the exhaust bits. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #809370 8th Jan 2020 5:54pm
Tommybahama32
Hi Jeffersj,
I put the rubber hangers in some hot water to soften them up and make them a bit more pliable.
Also use a bit of lube like vaseline, on the exhaust the metal hangers have a tab on them, bend those flat push them through the rubbers and the straighten them back up. Hope that helps.
Post #809372 8th Jan 2020 6:02pm
jeffersj
thanks Tommy. The hangers seem to be held in place on the bar with a washer, is this washer held with a split pin. Its not obvious. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #809374 8th Jan 2020 6:26pm
JOW240725
Take it to Demand Engineering! Thumbs Up Laughing James
Instagram @suffolk_rovers
Post #809380 8th Jan 2020 7:01pm
jeffersj
Top tips Tommy although did not need to soak in hot water. Greased rubber and inserts and they went on easier than they came off Thumbs Up All fitted successfully. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #809555 9th Jan 2020 2:42pm
