Home > Td5 > 110 wont turn off with key when lights are on
davidblythe
bought this ex utility 110 in May to use for work and am learning to work on them
with the lights on and engine running, when i come to stop the van, the ignition keys doesnt cut the engine, turning the lights off does
ignition keys works fine when the lights are not on, any ideas
pics of truck
Post #808876 5th Jan 2020 8:00pm
ickle
Faulty ignition switch (common) or bad earth somewhere (also common) multipoint on bulkhead, strap bulkhead to chassis as std, worth checking both and adding some more.
HTH Keith
Post #808877 5th Jan 2020 8:03pm
Rkcorry
A quick check of the rear light clusters may also be an idea, corrosion or wrong bulb in the brake lights, I had something similar on an ex utilities, given the lights have already been upgraded Whistle definitely worth a look.
Post #808891 5th Jan 2020 8:56pm
Does the engine stop if you have taken the key out then dip the clutch? Many utility vehicles are fitted with runlock systems to allow the vehicle to be locked with the engine running, and whilst you should need to press a switch to engage the system there are fault conditions which could activate it without. I wouldn't expect turning the lights on to stop it though.
Post #808942 5th Jan 2020 10:58pm
s55shh
common fault on S1 Lotus Elise when the cigar lighter is wired up back to front.
Post #808943 5th Jan 2020 10:59pm
davidblythe
will try in the morning
Post #808951 5th Jan 2020 11:37pm
Rkcorry
Something similar here. If the brake pedal has any bearing on this, it is worth checking the rear clusters, as current is travelling to the ignition via the contacts/bulb.
Post #809020 6th Jan 2020 4:38pm
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi,
Funny I did have the same with my td4 !
Do not know why but seems to go better after clean the ground cable attached to the transfert box
Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #809216 7th Jan 2020 5:00pm
Hazza
United Kingdom 1990 Defender 110 Td5 HT Bronze Green
I had the same issue on the td5, turned out that the wiring harness that runs through the front wing had chafed through and was shorting. 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #810522 16th Jan 2020 11:49am
