![]() | Home > Puma (Tdci) > Central Locking retrofit question. |
24heuer Member Since: 21 Jul 2015 Location: Edinburgh Posts: 179 ![]() ![]() ![]() |
Hi all,
I had the wiring for central locking and electric windows tucked away in the door pillars so just installed and connected up the in-door c/l components to the front doors this afternoon - genuine L/R door looms, actuators and rods etc. I didn't expect anything to happen with the fob until I get my 10AS modified but I was half expecting the passenger door lock to operate when I unlock/lock the driver's door with the key. Does this sound right at all? Probably a stupid question but..do I need to get the 10AS modified before any of it will work? Many thanks, Cheers, Andy... Edinburgh, Scotland http://24heuer.com |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1859 ![]() ![]() ![]() |
I can't remember exactly, but IIRC the power for the main unit in the drivers door comes from the 10AS. I used a remote mounted central locking relay off ebay to power mine, but the pcb is the same for central or non central locking units so if you can get a relay off a scrap disco or similar, the mods are pretty easy.
You can even remove the 10AS through the speaker grill if you've the patience. https://www.ebay.co.uk/itm/Central-Locking...2749.l2649 HTH keith |
Thanks for the reply Keith.
It makes sense that I need power from the 10AS to activate the solenoids in the actuators. I incorrectly thought it was 'always on' but looks like I do need to get the 10AS modified. I'm not confident enough to add the relay myself without stuffing up the circuit board completely ![]() So, I guess I'll remove it and send it to these guys to do for me - https://www.technozen-electronics.co.uk/la...-services/ While it's away, no 10AS means I can't drive it right? Thanks, Cheers, Andy... Edinburgh, Scotland http://24heuer.com |
cool, thanks for that
![]() I think I'll remove the 10AS and send it away - turnaround seems pretty quick. Do you know if I can get to both screws through the speaker hole or do I need to remove the instrument cluster etc. also? Thanks, Cheers, Andy... Edinburgh, Scotland http://24heuer.com |
stubby torx screwdriver and a bit of groping around to remove and the same with blutac to refit
good luck! |
There was a link to a video / set of instructions somewhere on here done by a Swedish? gent that showed in detail how to do it, the hard part is removing the 10AS - everything else is easy.
Be worth putting an internal +ve and -ve from the battery to the alarm whilst its in pieces - another layer if the external battery earth is cut, alarm will still work. HTH Keith |
Yer 'tis!
https://la7dja.org/defender/cdl/ |
Thanks
![]() Good tip - So now I need a stubby ratchet drive ![]() I can see the right hand screw but I can’t even feel the one on the left - I guess it’ll be fun locating it. There seems to be a big bit of black plastic in the way - looks like the dash was built round the flippin 10AS 😂 Cheers, Andy... Edinburgh, Scotland http://24heuer.com |
chrisc2306 Member Since: 02 Jan 2020 Location: Glasgow Posts: 60 ![]() ![]() ![]() |
Hi mate I've just finished doing this and done a wee write up about it here. Not sure if it'll be any use to you because you used land rover actuators but I hope it helps
https://www.defender2.net/forum/post809336.html#809336 |
Cheers m8,
I just removed my 10AS. Usual carry-on, shouting and swearing until I discovered that if you remove the steering column top/bottom covers (and the wheel), the left hand bolt is right in front of you and can be removed with a normal length drive ![]() ![]() Andy... Edinburgh, Scotland http://24heuer.com Last edited by 24heuer on 10th Jan 2020 12:01pm. Edited 1 time in total |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1125 ![]() ![]() ![]() |
I read both write-ups just out of interest
Hi MacFrank,
Thanks, but I’m not sure your comment is relevant to my post - I have no intention of taking a soldering iron to my 10AS - I”m way too terrified ![]() In fact it’s currently at Technozen getting modded right now ![]() Andy... Edinburgh, Scotland http://24heuer.com |
All working
![]() 10AS modded by Paul @ Technozen - super fast turnaround by the way - no idea how he did that so quick. Also included for £58 were 2 new fobs ![]() Reinstallation was a doddle now that the steering wheel and upper/lower covers were removed (5 minute job) - Left hand screw right in front using a bit of blu-tac on the end of the normal length drive to hold the screw to the torx bit, right hand screw up through the speaker hole using a stubby driver. Only collateral damage was a couple of door fasteners - luckily I planned for this and had a few spares on standby. Now I know the fronts are working, I'll tackle the rear side doors soon - the wiring's in the door pillars already so I might as well. Thanks everyone that commented and suggested different things ![]() Andy... Edinburgh, Scotland http://24heuer.com |
